5 Replies Latest reply on Jan 21, 2013 3:23 AM by Diircee
    Help with JavaScript
    Diircee
      Hi, i need help
      I have the code with row
      this.attributes.buyLabel = price == "free" ? "Baixar" : price || price == "$0.00" ? "Comprar "+price+"" : price;
      I need that variable price in code is blue
      But that the code does not change
      Someone help me?
      Dirce
        • 1. Re: Help with JavaScript
          I have a question, which is related to this, when I started looking for an answer to this question...
          I know that rich text is represented internally as a subset of XHTML (so far as I can see). Is there any JavaScript method to directly work with that XHTML, or is there only the abstraction represented by an array of Span and properties like Field.richValue?
          • 2. Re: Help with JavaScript
            Diircee Level 1
            Hi,   This file is connected with html.
            This is full code
            $(document).ready(function() {
                      var init = function() {
                                var parseIssues = function(xml) {
                                          var issueNodes = xml.getElementsByTagName("issue");
                                          var len = issueNodes.length;
                                          if (len > 0) {
                                                    var issues = [];
                                                    for (var i = 0; i < len; i++) {
                                                              var issueNode = issueNodes[i];
                                                              var issue = {};
                                                              var attributes = issueNode.attributes;
                                                              issue.id = attributes.getNamedItem("id").value;
                                                              issue.formatVersion = attributes.getNamedItem("formatVersion").value;
                                                              issue.version = attributes.getNamedItem("version").value;
                                                              issue.subpath = attributes.getNamedItem("subpath").value;
                                                              var childNodes = issueNode.childNodes;
                                                              var numNodes = childNodes.length;
                                                              for (var j = 0; j < numNodes; j++) {
        if (childNodes[j].nodeType == 1) {
        var nodeName = childNodes[j].nodeName;
        if (nodeName != "libraryPreviewUrl")
        issue[nodeName] = childNodes[j].firstChild.nodeValue;
        else
        issue[nodeName] = $.trim(childNodes[j].firstChild.nodeValue);
        if (childNodes[j].nodeName == "libraryPreviewUrl") {
        issue.hasLandscapeImage = childNodes[j].attributes.getNamedItem("landscapeVersion").value == "1";
        issue.hasPortraitImage = childNodes[j].attributes.getNamedItem("portraitVersion").value == "1";
                                                              issues.push(issue);
                                                    return issues;
                                          else
                                                    return null;
                                          var Folio = Backbone.Model.extend({
                                          initialize: function() {
                                                    var folio = folioDataHash[this.attributes.id];
                                                    if (folio) {
                                                              if (folio.state == 100 || folio.state == 200) {
        var price = folioDataHash[this.attributes.id].price.toLowerCase();
                                                              } else {
        this.attributes.buyLabel = "Visualizar";
                                                    else {
                                                              this.attributes.buyLabel = "Comprar";
                                var FolioCollection = Backbone.Collection.extend({
                                          model: Folio,
                                          url: FULFILLMENT_URL,
                                          parse: parseIssues
                                var FolioItemView = Backbone.View.extend({
                                          tagName:  "div",
                                          className: "folio",
                                          template: _.template("<img src='<%= libraryPreviewUrl %>/portrait' width='160' height='222' /><div id='title'><%= magazineTitle %></div><div id='issuenumber'><%=issueNumber%></div><div class='buyButton' id='<%= id %>'><%= buyLabel %></div>"),
                                          render: function() {
                                                    $(this.el).html(this.template(this.model.toJSON()));
                                                    return this;
                                var FolioView = Backbone.View.extend({
                                          el: $("#foliosContainer"),
                                          pageIndex: 0,
                                                    var html  = "<div id='foliosContainer'>";
                                                              html +=           "<div id='folios'>";
                                                              html +=                              "<table id='subscribe'>"; // Ugh: Use a table for layout rather than an image map otherwise the entire region gets a click rather than just a button. This is also faster to implement than placing buttons.
                                                              html +=                                        "<tr><td colspan='3'><a href='http://google.com.br'><img src='banner.png' width='768' height='395'></a></td></tr>";
                                                              html += "</table>";
                                                              html +=                    "</div>";
                                                              html += "</div>";
                                                    $("body").append(html)
                                                    _.bindAll(this, "removeMissingFolios");
                                                    folioCollection.bind("all", this.removeMissingFolios);
                                                    var scope = this;
                                                    $("#more").click(function(){ scope.addFolios()});
                                                    if (adobeExists()) {
                                                              adobe.dps.store.getFolioData(this.getFolioDataHandler);
                                                    } else { // API doesn't exist so testing on desktop.
                                                              folioCollection.fetch({dataType: 'xml'});
                                          getFolioDataHandler: function(data) {
                                                    var len = data.length;
                                                    if (len == 0) {
                                                              if (!this.interval) {
        var scope = this;
        this.interval = setInterval(function() {
        adobe.dps.store.getFolioData(function(data) {
        scope.getFolioDataHandler(data);
        }, 1000);
                                                              return;
                                                    clearInterval(this.interval);
                                                              folioDataHash[data[i].id] = data[i];
                                          addFolios: function() {
                                                    var numFoliosPerPage = this.pageIndex == 0 ? 10 : 12;
                                                    var delta = this.pageIndex == 0 ? 0 : -2;
                                                    var numFolios = Math.min(this.pageIndex * numFoliosPerPage + numFoliosPerPage + delta, folioCollection.length);
                                                    var scope = this;
                                                    for (var i = this.pageIndex * numFoliosPerPage + delta; i < numFolios; i++) {
                                                              var folio = folioCollection.at(i);
                                                              var view = new FolioItemView({model: folio});
                                                              $("#folios").append(view.render().el);
                                                              $("#" + folio.attributes.id).click(function(e){ scope.buy(e) });
                                                    this.pageIndex += 1;
                                          buy: function(e) {
                                                    var folio = folioDataHash[e.currentTarget.id];
                                                    if (folio.state == 100)
                                                              adobe.dps.store.buyFolio(folio.productId);
                                                              adobe.dps.store.viewFolio(folio.productId);
                                          removeMissingFolios: function() {
                                                              var len = folioCollection.length;
                                                              for (var i = len - 1; i >= 0; i--) {
        if (!folioDataHash[folio.attributes.id]){
        folioCollection.remove(folio, {silent: true});
                                                    this.addFolios();
                                          return itExists;
                                var folioDataHash = {};
                                var folioCollection = new FolioCollection();
                                var folioView = new FolioView();
                      if (window.connected)
                                init();
                      else
                                window.onnetworkconnection = init;
            • 3. Re: Help with JavaScript
              Diircee Level 1
              Got It
              JS
              Css
              #azul{font-size:12px;color:#2021C0;}
              Dirce
              • 4. Re: Help with JavaScript
                There is no CSS with Acrobat JavaScript. Are you sure you're in the right forum?
                • 5. Re: Help with JavaScript
                  Diircee Level 1
                  Sorry,  I put this code rs,
                  Sorry if I put in the wrong forum, was a little confused
