4 Replies Latest reply on Jan 22, 2013 1:36 PM by Laure Carnet
    final cut to photoshop to after effects back to final cut problem
    Laure Carnet
      Hello there,
      I shall explain my problem.
      I am working with three different programs. Finla cut 7, photoshop, and after effects.
      I have taken a jpeg still from final cut to work in photoshop.
      In phtoshop I have layered a project to work in after effects to make an animation.
      The animation is then exported back from after effects into final cut.
      When I do this I realise that the dimensions of the animation differs from the original sequence from where the still was taken.
      I work with PAL.
      The still from the sequence is 768 x 576. I create a still using 'export- Using quick time conversion'. I do not understand why the image obtained does not have the format 720x576 as it says the film sequences have in final cut pro settings.
      When I edit it in photoshop, I create an image that has the 'film-video' setting but the image still does not match the frame. I have noticed there was the setting PAL1/DV square pixel but it still does not match the original format after editing in after effect.
      Why is this?
      Thank you
