2 Replies Latest reply on Jan 19, 2013 8:07 AM by Peter Spier
    Add Pages from Other ID Doc
    luca del carlo Level 1
      How does one move pages from one ID doc to another? Both are the same size, but may or may not have differing masters.
      Thank you,
      Luca
        • 1. Re: Add Pages from Other ID Doc
          @Luca – Open source and target document(s).
          Then use the Pages panel.
          In the panel options there is: "Move Pages".
          First set the target document in the "Move to:" section, then the other options.
          Applied master pages will not travel over. You have to care for them separately…
          Uwe
          • 2. Re: Add Pages from Other ID Doc
            Actually, master pages WILL travel withthe document pages, but only if the have a different name from any master page in the receiving document.
            This logic applies to swatches and styles, too. If both documents have elements with the same name, but differnt definitions, the definitions in the receiving document will be used. This can have some unexpected effects on text, especially if you use "based on" styles.
