6 Replies Latest reply on Jan 22, 2013 9:38 AM by intj2
    Request URI too Large (414 Error)
    intj2
      I have a site which has been in operation for several years.  I am now getting 414 Errors - Request URI too Large -  from dyanamically generated pages.  No code changes have been made to the server.  I am looping over an array to build out a page.
      Here is some typical code:
      <form action="#request.self#" method="">
              <table width="98%" border="0" cellspacing="0" cellpadding="2">
                      <cfloop from="#evaluate(currentStartRow+1)#" to="#evaluate(currentStartRow+15)#" index="x">
                          <tr>
                              <td valign="top">
                                  <select class="small" name="checkType#x#">
                                      <cfloop list="#checkTypes#" index="y">
                                          <option value="#y#" <cfif allSteps[x].t is y>selected</cfif>>#y#</option>
                                      </cfloop>
                                  </select>
                                  <select class="small" name="stepIsActive#x#">
                                      <cfloop list="#stepStatus#" index="j">
                                          <option value="#j#" <cfif allSteps[x].i is j>selected</cfif>>#j#</option>
                                      </cfloop>
                                  </select>
                                  <select class="small" name="method#x#">
                                      <cfloop list="#methods#" index="jjj">
                                          <option value="#jjj#" <cfif allSteps[x].m is jjj>selected</cfif>>#jjj#</option>
                                      </cfloop>
                                  </select>
                               <textarea class="small" cols="62" rows="4" name="characteristic#x#">
                                  #trim(allSteps[x].c)#
                                </textarea>
                                  <input class="small" maxlength="30" name="zone#x#" size="22" value="#allSteps[x].z#">
                                  <input class="small" maxlength="10" name="valueA#x#" size="8" value="#allSteps[x].a#">
                                  <input class="small" maxlength="10" name="valueB#x#" size="8" value="#allSteps[x].b#">
                              </td>
                          </tr>
                      </cfloop>
                  <tr>
                      <td align="center">
                          <input class="smallButtonGreen" type="submit" value="`save" name="save">
                      </td>
                  </tr>
              </table>
      </form>
      If I set the loop counter lower the page processes.  If I comment out some of the content in the cfm file (meaning that the final page after processing is smaller) the page processes.  If I add  method= "post" the get a 500 Error.  Leaving out the method = "post" I get a 414 error.
      The pages in question have not been updated for months and are used everyday.  This problem started two days ago.  Any ideas on how I can figure out this issue?
        • 1. Re: Request URI too Large (414 Error)
          BKBK Adobe Community Professional & MVP
          I suspect the value of the string request.self  is too long. A tip for you: use method="get" and view the page source. Does it tell you anything? Could you show us the source?
          • 2. Re: Request URI too Large (414 Error)
            intj2 Level 1
            I thought size might have been an issue so I stripped out the cfform tags, javascript and the css and got the form down to html.  I am looping over some code 20 times to create the file below.
            I wanted to note that this problem is across two servers and my local dev PC.  I pulled code from November from our repository and it also failed.  I cannot come up with a reason on why it just stopped working.  It was used everyday by several clients without issue until this past week.
            <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
            <head>
            <title>XXXXXXXXXXX</title>
            <meta http-equiv="keywords" content="XXXXX">
            <meta http-equiv="description" content="XXXXXXXXXXXXXXXXX">
            <meta charset="UTF-8">
            </head>
            <body topmargin="5">
            <form action="index.cfm" method="get">
            <tr>
            <td valign="top">
            <select class="small" name="checkType1">
            <option value="accept/reject" selected>accept/reject</option>
            <option value="greater than" >greater than</option>
            <option value="less than" >less than</option>
            <option value="equal to" >equal to</option>
            <option value="between" >between</option>
            <option value="max" >max</option>
            <option value="min" >min</option>
            </select>
            <select class="small" name="stepIsActive1">
            <option value="yes" selected>yes</option>
            <option value="no" >no</option>
            </select>
            <select class="small" name="method1">
            <option value="A" selected>A</option>
            <option value="B" >B</option>
            <option value="C" >C</option>
            <option value="D" >D</option>
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic1">
            </textarea>
            <input class="small" maxlength="30" name="zone1" size="22" value="">
            <input class="small" maxlength="10" name="valueA1" size="8" value="">
            <input class="small" maxlength="10" name="valueB1" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType2">
            </select>
            <select class="small" name="stepIsActive2">
            </select>
            <select class="small" name="method2">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic2">
            </textarea>
            <input class="small" maxlength="30" name="zone2" size="22" value="">
            <input class="small" maxlength="10" name="valueA2" size="8" value="">
            <input class="small" maxlength="10" name="valueB2" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType3">
            </select>
            <select class="small" name="stepIsActive3">
            </select>
            <select class="small" name="method3">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic3">
            </textarea>
            <input class="small" maxlength="30" name="zone3" size="22" value="">
            <input class="small" maxlength="10" name="valueA3" size="8" value="">
            <input class="small" maxlength="10" name="valueB3" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType4">
            </select>
            <select class="small" name="stepIsActive4">
            </select>
            <select class="small" name="method4">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic4">
            </textarea>
            <input class="small" maxlength="30" name="zone4" size="22" value="">
            <input class="small" maxlength="10" name="valueA4" size="8" value="">
            <input class="small" maxlength="10" name="valueB4" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType5">
            </select>
            <select class="small" name="stepIsActive5">
            </select>
            <select class="small" name="method5">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic5">
            </textarea>
            <input class="small" maxlength="30" name="zone5" size="22" value="">
            <input class="small" maxlength="10" name="valueA5" size="8" value="">
            <input class="small" maxlength="10" name="valueB5" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType6">
            </select>
            <select class="small" name="stepIsActive6">
            </select>
            <select class="small" name="method6">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic6">
            </textarea>
            <input class="small" maxlength="30" name="zone6" size="22" value="">
            <input class="small" maxlength="10" name="valueA6" size="8" value="">
            <input class="small" maxlength="10" name="valueB6" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType7">
            </select>
            <select class="small" name="stepIsActive7">
            </select>
            <select class="small" name="method7">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic7">
            </textarea>
            <input class="small" maxlength="30" name="zone7" size="22" value="">
            <input class="small" maxlength="10" name="valueA7" size="8" value="">
            <input class="small" maxlength="10" name="valueB7" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType8">
            <option value="accept/reject" >accept/reject</option>
            </select>
            <select class="small" name="stepIsActive8">
            <option value="yes" >yes</option>
            </select>
            <select class="small" name="method8">
            <option value="A" >A</option>
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic8">
            </textarea>
            <input class="small" maxlength="30" name="zone8" size="22" value="">
            <input class="small" maxlength="10" name="valueA8" size="8" value="">
            <input class="small" maxlength="10" name="valueB8" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType9">
            </select>
            <select class="small" name="stepIsActive9">
            </select>
            <select class="small" name="method9">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic9">
            </textarea>
            <input class="small" maxlength="30" name="zone9" size="22" value="">
            <input class="small" maxlength="10" name="valueA9" size="8" value="">
            <input class="small" maxlength="10" name="valueB9" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType10">
            </select>
            <select class="small" name="stepIsActive10">
            </select>
            <select class="small" name="method10">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic10">
            </textarea>
            <input class="small" maxlength="30" name="zone10" size="22" value="">
            <input class="small" maxlength="10" name="valueA10" size="8" value="">
            <input class="small" maxlength="10" name="valueB10" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType11">
            </select>
            <select class="small" name="stepIsActive11">
            </select>
            <select class="small" name="method11">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic11">
            </textarea>
            <input class="small" maxlength="30" name="zone11" size="22" value="">
            <input class="small" maxlength="10" name="valueA11" size="8" value="">
            <input class="small" maxlength="10" name="valueB11" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType12">
            </select>
            <select class="small" name="stepIsActive12">
            </select>
            <select class="small" name="method12">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic12">
            </textarea>
            <input class="small" maxlength="30" name="zone12" size="22" value="">
            <input class="small" maxlength="10" name="valueA12" size="8" value="">
            <input class="small" maxlength="10" name="valueB12" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType13">
            </select>
            <select class="small" name="stepIsActive13">
            </select>
            <select class="small" name="method13">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic13">
            </textarea>
            <input class="small" maxlength="30" name="zone13" size="22" value="">
            <input class="small" maxlength="10" name="valueA13" size="8" value="">
            <input class="small" maxlength="10" name="valueB13" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType14">
            </select>
            <select class="small" name="stepIsActive14">
            </select>
            <select class="small" name="method14">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic14">
            </textarea>
            <input class="small" maxlength="30" name="zone14" size="22" value="">
            <input class="small" maxlength="10" name="valueA14" size="8" value="">
            <input class="small" maxlength="10" name="valueB14" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType15">
            </select>
            <select class="small" name="stepIsActive15">
            </select>
            <select class="small" name="method15">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic15">
            </textarea>
            <input class="small" maxlength="30" name="zone15" size="22" value="">
            <input class="small" maxlength="10" name="valueA15" size="8" value="">
            <input class="small" maxlength="10" name="valueB15" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType16">
            </select>
            <select class="small" name="stepIsActive16">
            </select>
            <select class="small" name="method16">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic16">
            </textarea>
            <input class="small" maxlength="30" name="zone16" size="22" value="">
            <input class="small" maxlength="10" name="valueA16" size="8" value="">
            <input class="small" maxlength="10" name="valueB16" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType17">
            </select>
            <select class="small" name="stepIsActive17">
            </select>
            <select class="small" name="method17">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic17">
            </textarea>
            <input class="small" maxlength="30" name="zone17" size="22" value="">
            <input class="small" maxlength="10" name="valueA17" size="8" value="">
            <input class="small" maxlength="10" name="valueB17" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType18">
            </select>
            <select class="small" name="stepIsActive18">
            </select>
            <select class="small" name="method18">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic18">
            </textarea>
            <input class="small" maxlength="30" name="zone18" size="22" value="">
            <input class="small" maxlength="10" name="valueA18" size="8" value="">
            <input class="small" maxlength="10" name="valueB18" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType19">
            </select>
            <select class="small" name="stepIsActive19">
            </select>
            <select class="small" name="method19">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic19">
            </textarea>
            <input class="small" maxlength="30" name="zone19" size="22" value="">
            <input class="small" maxlength="10" name="valueA19" size="8" value="">
            <input class="small" maxlength="10" name="valueB19" size="8" value="">
            </td>
            </tr>
            <tr>
            <td valign="top">
            <select class="small" name="checkType20">
            </select>
            <select class="small" name="stepIsActive20">
            </select>
            <select class="small" name="method20">
            </select>
            <textarea class="small" cols="62" rows="4" name="characteristic20">
            </textarea>
            <input class="small" maxlength="30" name="zone20" size="22" value="">
            <input class="small" maxlength="10" name="valueA20" size="8" value="">
            <input class="small" maxlength="10" name="valueB20" size="8" value="">
            </td>
            </tr>
            <tr>
            <td align="center">
            </td>
            </tr>
            </table>
            </form>
            </body>
            </html>
            • 3. Re: Request URI too Large (414 Error)
              I copy-pasted this source code as a CFM file, and ran it. No problems at all.
              • 4. Re: Request URI too Large (414 Error)
                intj2 Level 1
                In the code I posted the method was "get".
                The get should have been a POST.
                <form action="index.cfm" method="POST">
                I have a more time to look at this.  In the real production page we are using CFForm.  It uses fusebox 4.1 framework.  So the actual code look like:
                <cfform action="#request.self#" method="POST">  ---  This fails
                If I remove the POST and leave the method blank the page works.
                <cfform action="#request.self#" method=""> --- This works
                Can anyone make any sense of this?  I believe the default method for CFFORM is POST.  So the the two lines sould be identical.  Why would one work but not the other?
                pjh
                • 5. Re: Request URI too Large (414 Error)
                  Miguel-F Level 3
                  What version of ColdFusion are you using and have you applied ColdFusion Security Hotfix APSB12-06?  That hotfix adds a postParametersLimit restriction of 100 form fields.  Are you hitting that maybe???
                  I believe this security is also included with ColdFusion 10 and can be modified via the administrator.
                  • 6. Re: Request URI too Large (414 Error)
                    intj2 Level 1
                    Yes - I discovered the APSB13-03 Hot Fix includes APSB12-06.  We just adjusted the limit in our validation environment.  It seems to correct the issue.  See this link for details:  http://www.cutterscrossing.com/index.cfm/2012/3/27/ColdFusion-Security-Hotfix-and-Big-Form s
