14 Replies Latest reply: Jul 24, 2013 8:55 AM by dexpetkovic RSS
    CRXDE Unable to connect to repository
    Kristian Wright Community Member
      Hello all,
      I'm having trouble connecting CRXDE to my CQ5.5 repository with a particular server configuration.  When trying to login/connect to my server, I get the following messages popup from the CRXDE app:
      "Error initializing workspace: No file system is defined for scheme: jcr"
      Whe I click this away, another popup appear with:
      "An error has occurred.  See the log file D:\users\kristian\.crxde\.metadata\.log."
      After clicking that message away, CRXDE closes.
      The output of the log file is:
      !SESSION 2013-01-20 11:06:21.994 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.7.0_07
      java.vendor=Oracle Corporation
      BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_AU
      Command-line arguments:  -os win32 -ws win32 -arch x86_64
      !ENTRY org.eclipse.osgi 4 0 2013-01-20 11:06:55.166
      !MESSAGE Application error
      !STACK 1
      java.lang.reflect.InvocationTargetException
                at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:121)
                at com.day.cq.ide.CQDEApplication.start(CQDEApplication.java:62)
                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                at java.lang.reflect.Method.invoke(Unknown Source)
                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
                at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
      Caused by: org.eclipse.core.runtime.CoreException: No file system is defined for scheme: jcr
                at org.eclipse.core.internal.filesystem.Policy.error(Policy.java:55)
                at org.eclipse.core.internal.filesystem.Policy.error(Policy.java:50)
                at org.eclipse.core.internal.filesystem.InternalFileSystemCore.getFileSystem(InternalFileSys temCore.java:65)
                at org.eclipse.core.internal.filesystem.InternalFileSystemCore.getStore(InternalFileSystemCo re.java:107)
                at org.eclipse.core.filesystem.EFS.getStore(EFS.java:350)
                at com.day.cq.ide.fs.JCRFileSystemPlugin.registerExtensions(JCRFileSystemPlugin.java:100)
                at com.day.cq.ide.init.SetupWorkspaceOperation.initWorkspace(SetupWorkspaceOperation.java:16 6)
                at com.day.cq.ide.init.SetupWorkspaceOperation.execute(SetupWorkspaceOperation.java:119)
                at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
                at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1800)
                at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
                ... 14 more
      Root exception:
      The error.log on the CQ5 instance outputs the following when trying to connect:
      20.01.2013 11:47:04.232 *WARN* [123.456.789.012 [1358642824230] GET /bin/crxde.classpath.xml HTTP/1.1] com.day.crx.ide.CRXDEServlet bundle location is not an URI: System Bundle
      20.01.2013 11:47:04.235 *INFO* [123.456.789.012 [1358642824230] GET /bin/crxde.classpath.xml HTTP/1.1] org.apache.jackrabbit.core.persistence.bundle.AbstractBundlePersistenceManager cachename=crx.defaultBundleCache[ConcurrentCache@2f202573], elements=2476, usedmemorykb=8188, maxmemorykb=8192, access=5024501, miss=864065
      I know my CRXDE app is functional, as it does connect to a localhost instance, and also other remote instances.  Also, I get the same results from this server running CRXDE from different conputers with different Java versions.  So I have the feeling that my server setup here may have something to do with it, and I might need to tweak some OSGI settings somewhere, but I'm not sure what...
      I use an Apache server as a gateway to my CQ5 servers.  The Apache server takes https requests (on 443, or 80 which auto-redirects to 443) and then uses a Reverse Proxy to send the traffic to the required CQ5 server based on the host name.  So https://mycq5auth.company.com hits my Apache server on port 443, and Apache then sends the traffic to an internal (non internet facing) CQ5 author server on port 4502.  CQ5 does it's thing, sends the traffic back to Apache, which then serves it back out on 443.
      All of this works great in the browser - the entire CQ5 instance works, including the OSGI console, CRXDE Lite etc - everything.  Only the CRXDE app seems to be having issues with this config.
      I've had a google around for solutions, but I haven't come across too much regarding these errors.
      Anyone have any suggestions on what I might try to resolve this?
      K
        • 1. Re: CRXDE Unable to connect to repository
          Krishna Kancherla Community Member
          Delete .crxde folder under "D:\users\kristian\" and try once.
          • 2. Re: CRXDE Unable to connect to repository
            Hi Krishna,
            I've had a problem in the past where CRXDE would not connect to a CQ5 instance at all, and deleting the .crxde folder did solve that issue.  Unfortunatelty deleting that folder does not work in this case.  With this particular issue, CRXDE does connect with the CQ5 server, but it errors when it does.
            • 3. Re: CRXDE Unable to connect to repository
              I discovered the problem - it was in my Apache Virtualhost configuration.
              When using a standard http connection, CRXDE had no problem with the ProxyPreserveHost directive being set to on.  But with the https connection, having this set causes the above issue with CRXDE.  After removing that directive from the secure virtualhost, then CRXDE connects to the repo correctly.
              Hope this helps someone!
              Cheers,
              K
              • 4. Re: CRXDE Unable to connect to repository
                I spoke too soon...
                The setting of ProxyPreserveHost to 'off' allows CRXDE to connect to the repo, but then any POSTs to the site get 403 rejected.  This includes logging in, so with ProxyPreserveHost On I can use the website normally, but CRXDE won't connect, but with ProxyPreserveHost Off CRXDE can connect but I can login (or do any other post) to the server.  I'm going directly to the author instance, so there's no dispatcher involved here.
                I'll keep looking at it and when I find a suitable config I'll post it here.
                K
                • 5. Re: CRXDE Unable to connect to repository
                  Ove Lindström Community Member
                  What version of CRXDE are you running? I've seen this behaviour using CRXDE 1.0.1 with CQ5.5 but using CRXDE 1.0.2 solved it.
                  • 6. Re: CRXDE Unable to connect to repository
                    Hi Ove,
                    I know I've run 1.0.1 in the past, so I just reinstalled 1.0.2 again on a new machine to make sure.  Exactly the same issues above:
                    http - connects ok
                    https (ProxyPreserveHost On) - fails to connect with error
                    https (ProxyPreserveHost On commented out) - connects, but all other POST to server fail with 403 errors
                    • 7. Re: CRXDE Unable to connect to repository
                      pratap_121 Community Member
                      Hello all,
                      I'm also having trouble connecting CRXDE to my CQ5.5 repository with weblogic server.  When trying to login/connect to my server, I get the same messages popup from the CRXDE app.
                      I am using this url during repositiory login : http://localhost:7001/cq-author
                      Regards
                      Pratap
                      • 8. Re: CRXDE Unable to connect to repository
                        Hi Pratep,
                        I've not run CQ5.5 on top of WebLogic so far, so I'm not sure what might be happening here.  Can you connect from another machine (not localhost)?  Also, what is the exact error message you are getting from either CRXDE or any of the CQ5 logs?
                        • 9. Re: CRXDE Unable to connect to repository
                          I tried to connect with other machine also instead on localhost. But the sam msg is coming.
                          It gives pop up saying:
                          "Error initializing workspace:Plugi-in "com.day.cq.ide.fs" was unable to instantiate class " com.day.cq.ide.fs.jcr.JCRFileSystem". "
                          an error has occured. See the log file
                          C:\Users\prataps\.crxde\.metadata\.log.
                          And in the log file the error is :
                          java.version=1.6.0_29
                          java.vendor=Sun Microsystems Inc.
                          BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
                          !ENTRY org.eclipse.core.resources 2 10035 2013-02-01 17:33:09.435
                          !MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
                          !ENTRY org.eclipse.osgi 4 0 2013-02-01 17:42:38.077
                          !STACK 1
                          Caused by: org.eclipse.core.runtime.CoreException: Plug-in "com.day.cq.ide.fs" was unable to instantiate class "com.day.cq.ide.fs.jcr.JCRFileSystem".
                          at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrat egyOSGI.java:180)
                          at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Re gistryStrategyOSGI.java:172)
                          at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionR egistry.java:874)
                          at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Configu rationElement.java:243)
                          at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(C onfigurationElementHandle.java:51)
                          at org.eclipse.core.internal.filesystem.InternalFileSystemCore.getFileSystem(InternalFileSys temCore.java:70)
                          ... 13 more
                          Caused by: org.eclipse.core.runtime.CoreException: Repository Error
                          at com.day.cq.ide.util.plugin.Policy.throwError(Policy.java:37)
                          at com.day.cq.ide.fs.jcr.JCRFileSystem.<init>(JCRFileSystem.java:88)
                          at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
                          at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
                          at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
                          at java.lang.reflect.Constructor.newInstance(Unknown Source)
                          at java.lang.Class.newInstance0(Unknown Source)
                          at java.lang.Class.newInstance(Unknown Source)
                          at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Re gistryStrategyOSGI.java:170)
                          ... 25 more
                          Caused by: javax.jcr.ItemNotFoundException: Not Found
                          at org.apache.jackrabbit.spi2dav.ExceptionConverter.generate(ExceptionConverter.java:100)
                          at org.apache.jackrabbit.spi2dav.ExceptionConverter.generate(ExceptionConverter.java:51)
                          at org.apache.jackrabbit.spi2dav.ExceptionConverter.generate(ExceptionConverter.java:45)
                          at org.apache.jackrabbit.spi2dav.RepositoryServiceImpl.getRepositoryDescriptors(RepositorySe rviceImpl.java:560)
                          at org.apache.jackrabbit.jcr2spi.RepositoryImpl.<init>(RepositoryImpl.java:82)
                          at org.apache.jackrabbit.jcr2spi.RepositoryImpl.create(RepositoryImpl.java:95)
                          at com.day.crx.jcr.client.Client.getRepository(Client.java:206)
                          at com.day.cq.ide.fs.jcr.JCRFileSystem.<init>(JCRFileSystem.java:66)
                          ... 32 more
                          Caused by: org.apache.jackrabbit.webdav.DavException: Not Found
                          at org.apache.jackrabbit.webdav.client.methods.DavMethodBase.getResponseException(DavMethodB ase.java:165)
                          at org.apache.jackrabbit.webdav.client.methods.DavMethodBase.checkSuccess(DavMethodBase.java :174)
                          at org.apache.jackrabbit.spi2dav.RepositoryServiceImpl.getRepositoryDescriptors(RepositorySe rviceImpl.java:530)
                          ... 36 more
                          Root exception:
                          ... 25 more
                          ... 32 more
                          ... 36 more
                          Regards
                          Pratap
                          • 10. Re: CRXDE Unable to connect to repository
                            I was wondering if anyone from Adobe had thoughts on this - it seems it's not an isolated incident...
                            K
                            • 11. Re: CRXDE Unable to connect to repository
                              Does anyone know of any documentation regarding what Apache modules can and can't be used with CQ5, or other Apache / CQ5 config details?  I'm not meaning anything dispatcher related, but just accessing CQ5 via Apache.
                              Any shove in the right direction would be appreciated.
                              Cheers,
                              K
                              • 12. Re: CRXDE Unable to connect to repository
                                Tim Goodman Community Member
                                The same error occured in CRXDE which ships with LiveCycle ES4
                                The solution was:
                                1. open web console: http://127.0.0.1:8080/lc/system/console/configMgr
                                2. menu OSGi -> Configuration
                                3. find end open CRXDE Servlet
                                4. change URL from /crx/server to /lc/crx/server
                                Not sure if this gives any pointers for your server....
                                • 13. Re: CRXDE Unable to connect to repository
                                  Hi Tim,
                                  Same symptoms, but different problem I think.  From what I've seen of ES4, the CRX repository has been moved under a /lc folder, which is different to the standard CQ CRX location.  I checked the OSGi setting to see if I could set the protocol to https (which is my issue), but it only allows changing of the path, not the protocol.  I'll keep digging - maybe there's another config setting that I'm missing...
                                  Cheers,
                                  K
                                  • 14. Re: CRXDE Unable to connect to repository
                                    dexpetkovic Community Member
                                    Hello Gents, has there been any resolution on the 403s from the CQ5?
