7 Replies Latest reply on Jan 21, 2013 1:53 AM by UlfLaursen
    Another "What goes where" thread
    UlfLaursen Level 2
      Hi guys
      I am a little unsure how to configure "what goes where" on my main rig.
      I have these discs:
      Corsair 256 GB Pro (holds atm system, program files and pagefile)
      Single 1.5 TB WD black (all kinds of stuff other than video)
      Raid 0 on LSI 4 chnl. ctr. - 2 x Caviar 600 GB (holds now project files and maedia for PPRO)
      Raid 0 on LSI 4 chnl. ctr. - 2 x Caviar 1 TB (holds render now)
      SSD 240 GB for mediacache and preview for both AE and PPRO CS6
      Should I add another single disc for project files alone and/or move the pagefile?
      Ulf
        • 1. Re: Another "What goes where" thread
          Jim_Simon Level 9
          You should break out the RAID's like thus:
          256 GB - OS and Programs
          600 GB - Projects
          600 GB - Scratch/Cache
          240 GB - AE Global Cache
          1.5 TB - Media
          1 TB - Exports
          1 TB - Backup and Archive
          • 2. Re: Another "What goes where" thread
            Harm Millaard Level 7
            Jim, I completely agree considering your own system, but not on Ulf's system, which is way faster than yours.
            Ulf,
            If you want to add another two disks, I suggest:
            C: 256 GB OS & programs & pagefile, SATA 6G
            D: 240 GB Windows temp & media cache & AE cache, SATA 6 G
            E:  2 x 600 WD in raid0 on the Marvell controller, previews. SATA 6G
            F: 4 x 1 TB in raid5 on the LSI for media and projects
            G: 1.5 TB exports and backup.
            FYI, yesterday Bill gave me some experimental figures on the new test we are working on. Exporting a two hour timeline on an i7-2600K with a single OCZ Vertex4 SSD was around 6 times slower compared to a system with a heavy raid array. 84 seconds versus 14 seconds. Jim's suggestion to break out the raids you currently have will only slow down your system. In Jim's case he will not notice it, because his system is so much slower than yours, but you definitely will notice it.
            The complicating factor in your case is the variety of disks you have and only a 4 port controller. The E: drive is way too big for previews only, but you don't have many choices for alternative uses and despite that they are older drives, in a raid0 they do give you nice performance. Going from 2 x 1 TB raid0 to 4 x 1 TB raid5 on that controller will give you added performance plus security against disk failure. Don't expect miracles in performance boost from 2x R0 to 4x R5, it will probably be only 25-35% or around that figure.
            • 3. Re: Another "What goes where" thread
              UlfLaursen Level 2
              Thanks a lot guys - got something to work with now
              @Harm: the 4 x 1TB you suggest in raid 5, is that with a hot spare or will I get 4 TB to use. And woul you make one volume only or two volumes on the raid 5?
              Thanks.
              /Ulf
              • 4. Re: Another "What goes where" thread
                RjL190365 Level 5
                Ulf,
                Use only one volume on the RAID 5. Using two volumes on a single RAID 5 array will have the same effect as partitioning single disks into multiple volumes: Increased overhead, slower performance if anything besides the primary partition is accessed and increased and uneven physical wear and tear in the disks.
                • 5. Re: Another "What goes where" thread
                  UlfLaursen Level 2
                  /Ulf
                  • 6. Re: Another "What goes where" thread
                    Ulf,
                    In addition to what Randall said, the 4 disks in raid5 are without a hot spare, for the simple reason you have only 4 ports on your controller. You will effectively have 3 TB of capacity, 1 TB is lost to parity, but that is the security you get. And I agree with Randall that you should not make more volumes on that array. Leave it as a single large volume.
                    • 7. Re: Another "What goes where" thread
                      UlfLaursen Level 2
                      Thanks, Harm...
                      /Ulf
