5 Replies Latest reply on Nov 27, 2007 4:10 AM by atta707
    set runtime period
    ljonny18
      Hi
      I am getting a runtime error:
      1502 A script has executed for longer than the default timeout period of 15 seconds.
      This is expected from my application, however I want to reduce this runtime period to 10 seconds – is this possible???? And if it is – how can I do this
      Additionally, I want to retrieve the runtime values every 5 seconds.
      My application is being refreshed every 5 seconds, and on this refresh, I want to check the current runtime values so I can perform a condition on it, e.g:
      If (runtime > 5 secons)
      do something
      id this also possible???
      Please let me know,
      Thanks again,
      Jon.
        • 1. Re: set runtime period
          ntsiii Level 3
          The Application has a scriptTimeoutLimit property you can set. The maximum is 60 seconds.
          Tracy
          • 2. Re: set runtime period
            ntsiii Level 3
            You can also read this property of course.
            Tracy
            • 3. Re: set runtime period
              ljonny18 Level 1
              thanks tracy, again will give it a go and let you know.
              Jon.
              • 4. Re: set runtime period
                ljonny18 Level 1
                Hi Tracy - thanks for your help.
                let me try to explain my problem further as I did not do a good jab last time.
                my application is refreshing getting data from an XML file - this process is being refreshed every 5 seconds (new data is being refreshed form the XML file):
                <mx:HTTPService
                id="myResults"
                url=" http://localhost/results.xml"
                resultFormat="e4x"
                result="resultHandler(event)" />
                //run on application startup initialisation
                private function initApp():void
                myResults.send();
                private function resultHandler(event:ResultEvent):void
                myDataFeed = event.result as XML;
                timerPulse = new Timer(5000, 1);
                timerPulse.addEventListener(TimerEvent.TIMER, timerRefresh);
                timerPulse.start(); //start timer
                //do stuff here
                private function timerRefresh(eventObj:TimerEvent):void
                myResults.send();
                The above is all fine!!!
                However, if I leave my application running for a very long time, I get the following error:
                Although my application is very heavy.. I guess I have a memory leak somewhere in my application - however this is another problem.....
                What I want is some way to test that my application is becoming slow, and refresh it when it needs to - to prevent this error occurring.
                For example - I want to test against how long the script has been running and call a function that can refresh my application if the script has been running for longer than say 10 seconds
                Like a sort of "Panic Refresh".
                E.g.:
                if( script has executed for longer than 10 seconds )
                //do panic refresh
                My panic refresh will simply call a JavaScript function within my HTML embedder, so that is not a problem.
                My problem is to actually test against how long a script has been executed therefore knowing when to perform my panic refresh.
                Do you understand??? Any suggestion?
                Jon.
                • 5. Re: set runtime period
                  atta707 Level 2
                  Jon,
                  Try setting the weekRef parameter to
                  timerPulse.addEventListener(TimerEvent.TIMER, timerRefresh, false, 0, true /* week ref*/);
                  This would help the garbage collector.
                  I think another -- perhaps a better approach -- would be to start the timer in the init method instead of the result handler and let it run forever.:
                  myResults.send();
                  timerPulse = new Timer(5000, 0);
                  Notice the second parameter to Timer is set to 0; that means run infinitely.
                  my rationale is that you have ONLY one timer and let it poll after every 5 seconds instead of creating a new one everytime you've your XML file from the server.
                  I hope this makes sense to you and would solve the problem!
                  ATTA
