3 Replies Latest reply on Nov 19, 2007 5:23 PM by kglad
    mp3 player
    P_e_r_o
      Hello!
      I have a problem with my mp3 player. It loads songs thru xml. It has four buttons: play, pause, next and mute.
      I have five songs in my folder. The problem is, when I press the next button a couple of times to go to song 5 It starts loading all five songs and it slows my site down. I want it to load just the song I am listening too.
      Please help!
      Thanks!
        • 1. Re: mp3 player
          oh, i see you have a coding problem.
          • 2. Re: mp3 player
            P_e_r_o Level 1
            It loads mp3s over and over again, I would like that it loads just the song you are listening to.
            this is the code of my mp3 player:
            //setup sound object
            var s:Sound = new Sound();
            s.onSoundComplete = playSong;
            s.setVolume(75);
            //Array of songs
            var sa:Array = new Array();
            //Currently playing song
            var cps:Number = -1;
            //Current volume
            var cv:Number = 75;
            //Load the songs XML
            var xml:XML = new XML();
            xml.ignoreWhite = true;
            xml.onLoad = function(){
            var nodes:Array = this.firstChild.childNodes;
            for(var i=0;i<nodes.length;i++){
            sa.push(new Song(nodes .attributes.url, nodes.attributes.artist, nodes .attributes.track));
            playSong();
            xml.load("songs.xml");
            //Play the MP3 file
            function playSong():Void {
            s = new Sound();
            mute.gotoAndStop("on");
            if (cps == sa.length-1) {
            cps = 0;
            s.loadSound(sa[cps].earl, true);
            } else {
            s.loadSound(sa[++cps].earl, true);
            s.setVolume(cv);
            infoTrack.text = sa[cps].artist + " - " + sa[cps].track;
            playPause.gotoAndStop("pause");
            //pause the music
            function pauseIt():Void{
            pos = s.position;
            s.stop();
            //unpause the music
            function unPauseIt():Void{
            s.start(pos/1000);
            //Next button
            next.onRollOver = function(){
            this.gotoAndStop("nextOver");
            next.onRollOut = next.onReleaseOutside = function(){
            this.gotoAndStop("next");
            next.onRelease = function(){
            playSong();
            //postion of music
            var pos:Number;
            //-------playPause toggle
            playPause.onRollOver = function(){
            if(this._currentframe == 1){
            this.gotoAndStop("pauseOver");
            }else{
            this.gotoAndStop("playOver");
            }//playPause.onRollOver
            playPause.onRollOut = function(){
            if(this._currentframe == 10){
            this.gotoAndStop("pause");
            }else{
            this.gotoAndStop("play");
            playPause.onRelease = function(){
            pauseIt();
            }else{
            unPauseIt();
            }//playPause.onRelease
            //-------Audio Controls
            //-------muteSoundOn toggle
            muteSoundOn.onRollOver = function(){
            this.gotoAndStop("onOver");
            }else{
            this.gotoAndStop("offOver");
            }//muteSoundOn.onRollOver
            muteSoundOn.onRollOut = muteSoundOn.onReleaseOutside = function(){
            this.gotoAndStop("on");
            }else{
            this.gotoAndStop("off");
            muteSoundOn.onRelease = function(){
            volScrub._xscale = 0;
            s.setVolume(0);
            cv = 0;
            //trace(cv);
            }else{
            volScrub._xscale = 75;
            s.setVolume(75);
            cv = 75;
            //trace(cv);
            }//muteSoundOn.onRelease
            • 3. Re: mp3 player
              use the trace() function to narrow your problem. then if you're having trouble, use the attach code option to copy and paste just the relevant portion of your code.
