1. Re: How to turn off Highlight Existing Fields
Gilad D (try67) Jan 21, 2013 2:41 AM (in response to Schurgers1982)This is a setting of the application, not of the document.
You can switch it off by going to Edit - Prefs. - Forms, and tick off "Show
border hover color for fields".
It is also possible to switch this setting off using a script, but I would
advise against doing that because this would affect not just your file but
all the files opened on the user's computer. If you want to implement it
you should at least inform the user of the change and preferably get their
confirmation to doing so.
2. Re: How to turn off Highlight Existing Fields
Schurgers1982 Jan 21, 2013 8:35 AM (in response to Schurgers1982)Thanks for your reply!
3. Re: How to turn off Highlight Existing Fields
MSR1306 Jul 14, 2014 2:18 PM (in response to Schurgers1982)In the above answer it said as below,
I saved a copy of PDF, which is I developed via LC. In that saved copy I did as MENU -- EDIT -- PREFERENCES -- Disabled the chk box. Then, I opened the another form on browser, but, still button is turn ON by default
Pls. guide me where I have to do this setting, is it when I am developing my_form in LC or opening any PDF on my desktop & do setting on this PDF?
Pls. let me know where I hv to to do this seetings?
Thank you
4. Re: How to turn off Highlight Existing Fields
MSR1306 Sep 4, 2014 3:58 PM (in response to Gilad D (try67))Hello,
We are a multi national private company, located in Washington DC, we are looking for a expert LC developer with excellent JS expertise, its 3 months project, pls. reply ASAP if you are available, interviews will be immediate (no remote work pls.)
Thank you
