7 Replies Latest reply on Jan 21, 2013 10:00 AM by edu_tiny
    AE CS5 0::42 error on start
    edu_tiny Level 1
      Hi all
      My AE CS5 has started crashing on start after changing my preferences.
      I've been working without any problem with CS5 for years on the same computer. Recently, i formatted and re-installed it and installed CS5 again. I played around with it for a few days and today i changed my preferences. After changing Cache Folder it gave me an error (don't remember exactly, but i think it may have been related with the choosed folder, in Windows\Temp) and crashed. After that I've been having the same error on start:
      After Effects error: Last registered message: <5920> (this number has changed) <AppDirs> <5> Required Dir = C:\Program Files\Adobe\Adobe After Effects CS5\Support Files\Required
      AE can't continue. etc etc... (0 :: 42)
      I've followed the recommended solving paths: uninstall CS5, clean using Adobe Removal Tool and re-install, also deleting Prefs folder in AppData\Roaming\ folder and un-installing Quicktime. None of them worked. So, here I am.
      I work on a
      HP DV6 Laptop
      Intel i7 Q720 @ 1.60 GHz
      4GB RAM
      ATI Radeon HD 5650
      Thanks to anyone giving any hint.
        • 1. Re: AE CS5 0::42 error on start
          edu_tiny Level 1
          I forgot, using Windows 7 SP1 Home Edition
          And Windows and AE are fully updated.
          • 2. Re: AE CS5 0::42 error on start
            Check the System Event Viewer and provide the info there.
            Mylenium
            • 3. Re: AE CS5 0::42 error on start
              edu_tiny Level 1
              Hi Mylenium
              Thank you for listening.
              I've checked the Event Viewer and this is the provided info. Please, tell me if you need more info.
              -System
              -Provider
              [ Name] Application Error
              -EventID1000
              [ Qualifiers] 0
              Level2
              Task100
              Keywords0x80000000000000
              -TimeCreated
              [ SystemTime] 2013-01-21T14:25:16.000000000Z
              EventRecordID6008
              ChannelApplication
              ComputerHP_DV6
              Security
              -EventData
              AfterFX.exe
              10.0.0.458
              4bb2fd36
              CoolType.dll
              5.7.82.7449
              4b7b1af3
              c0000005
              00000000000739ea
              ee4
              01cdf7e318f55dd7
              C:\Program Files\Adobe\Adobe After Effects CS5\Support Files\AfterFX.exe
              C:\Program Files\Adobe\Adobe After Effects CS5\Support Files\CoolType.dll
              60018d53-63d6-11e2-9f22-c28e14d9a14d
              -System
              -Provider
              [ Name] Windows Error Reporting
              -EventID1001
              [ Qualifiers] 0
              Level4
              Task0
              -TimeCreated
              [ SystemTime] 2013-01-21T14:25:21.000000000Z
              EventRecordID6009
              ChannelApplication
              ComputerHP_DV6
              Security
              -EventData
              16079963
              4
              APPCRASH
              No disponible
              0
              AfterFX.exe
              10.0.0.458
              4bb2fd36
              CoolType.dll
              5.7.82.7449
              4b7b1af3
              c0000005
              00000000000739ea
              C:\Users\Edu\AppData\Local\Temp\WERFE8.tmp.WERInternalMetadata.xml
              C:\Users\Edu\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_AfterFX.exe_2a5e13 7aefab45f3e322e089b7afa8f63ced989c_14fa21a4
              0
              0
              • 4. Re: AE CS5 0::42 error on start
                CoolType.dll
                You have the "bad font" blight. Check your fonts and remove any that you may have added recently.
                Mylenium
                • 5. Re: AE CS5 0::42 error on start
                  edu_tiny Level 1
                  I've removed recent fonts, reset to default ones, cleaned up Registry using CCleaner, deleted Prefs folder at AppData\Roaming and uninstalled-reinstalled.
                  Nothing worked. Do you have another idea of what may be causing the problem?
                  • 6. Re: AE CS5 0::42 error on start
                    It's definitely a font issue. Updated your graphics driver recently? If so, invalid cached font info may be used. Likewise, deleting the Windows font cache file in your system folder may help.
                    Mylenium
                    • 7. Re: AE CS5 0::42 error on start
                      edu_tiny Level 1
                      Ok, Mylenium. Thanks a lot.
                      I'll try to fix it and post the solution if i get one.
