1 Reply Latest reply on Jan 21, 2013 7:48 AM by Jump_Over
    New paragraph in number list
    james_dean1986 Level 1
      I have just been working on a document with a lot of multilevel numbered lists and came came across an irritaing problem which I hope there is a simple solution to.
      Some of the sections have more than one paragraph. If I hit return it creates a new paragraph with a number. If I use the a forced line break I do not get the correct spacing after/before the paragraph.
      The example I have attached, I ended up removing the numbering and indenting the paragraph to the same level, but when you have to do it more than once it become a pain.
      I suspect there is an easier way to do multiple paragraphs under one number or bullet.... I hope!
        • 1. Re: New paragraph in number list
          Jump_Over Level 5
          You could create a new paraStyle with desired formatting (no numbering list, proper indent).
          So your text would look like:
          header (paraStyle1)
               subheader (paraStyle2)
               no_list (paraStyle3)
          header (paraStyle1)
               subheader... (paraStyle2)
          and so on (a logic of list should be kept)
          rgds
