2 Replies Latest reply on Nov 20, 2007 5:43 AM by Captiv8r
    Removing the next and back button
    Ashishtech
      As you all aware that the Next and back button appearing on the top of the TOC does not work and is of no use. How do we get rid of these two buttons.
      Some knows how to do it?
      Ashish
        • 1. Re: Removing the next and back button
          RoboColum(n) Level 5
          Hi Ashish.
          If you really, really don't want those buttons you can "remove" them with a slight of hand. If you edit your skin, you'll see the "Next" and "Previous" buttons displayed in the Nav Bar panel. Create an image one pixel in height and width of the same colour as the skin background. Next edit each of these buttons and add a custom image specifying your one pixel file name. Although the buttons are there, they are tiny and no user will see them.
          • 2. Re: Removing the next and back button
            Hi all
            In addition to what Colum offered, these can be "turned off" when generating your WebHelp. The trick is to double-click the layout in the Single Source Layouts area. Then click the Next > button. You should see an option labeled "Browse Sequences". It's probably selected. Just click to remove the check mark, generate and you should be golden.
            Just an FYI on the original complaint. The buttons actually DO serve a purpose. Odds are, you are simply misunderstanding what they are intended to do. Perhaps if you take a look at the link below, it will make more sense to you.
            Click here
            Cheers... Rick
