2 Replies Latest reply on Jan 22, 2013 8:03 PM by 1schulte1
    Why doesn't Editor open either from organizer or on the start screen?
    1schulte1 Level 1
      In Elments 11, all worked well after install.
      Now, weeks later, Editor will not open.
      Suggestions please!
      Thanks much
        • 1. Re: Why doesn't Editor open either from organizer or on the start screen?
          27Prac Level 3
          Please try couple of probable solutions as mentioned below:
          Solution 1:
          1. Close Elements.
          2. Launch the Photoshop Elements Welcome Screen and hold down ctrl + alt + shift as you click Editor.
          3. Continue to hold the keys until you see a message box asking if you want to delete Photoshop Elements settings file; click Yes. Elements will open with default preferences.
          Solution 2: In case any network printer is attached try to launch without network or printer uninstall or make different printer as default.
          Solution 3: Try launching with anti-virus off or removing PSE from conflicting list.
          Solution 4: Launch Editor directly from the exe. Go to C:\Program Files (x86)\Adobe\Photoshop Elements 11" and launch PhotoshopElementsEditor.exe
          • 2. Re: Why doesn't Editor open either from organizer or on the start screen?
            1schulte1 Level 1
            Thanks so much for your input.
            Sometimes, the most elegant solutions are the dumbest ones.
            I re-booted and all is fine
            But, I have saved your comments for future reference.
            Cheers
