4 Replies Latest reply on Jan 23, 2013 1:32 PM by ajguy711
    How can I play a symbol when it reaches a certain position?
    ajguy711
      I'm assuming there's some javascript code that can easily accomplish what I'm shooting for, but here's what I've got. I have an Animate page with several vertically stacked symbols extended below the main stage. As the user scrolls through the symbols, I would like to have each one play when its vertical position reaches 0. Is there any way to accomplish this within Edge Animate?
        • 1. Re: How can I play a symbol when it reaches a certain position?
          joel_pau Level 5
          Well, i am trying to understand your post (what's your goal).
          So, 2 ideas: one using mousemove, another without mousemove.
          It's very easy using Edge Animate UI.
          Edge provides you tools: mousemove, e.pageX, epageY.
          Here is one example (a first idea).
          1) We add one mousemove event using Edge Animate UI: doubleclick on mousemove.
          Well, i chose Stage but you can choose another object on Stage.
          2) We add epageX and epageY using Edge Animate UI: click on e.
          Whenever you see an e orange, epageX and epageY are available.
          If i want to know and see mouse position:
          1) I add a text box on Stage,
          2) and on Stage.mousemove i write this code: sym.$("Text").html("x="+e.pageX+" and y="+e.pageY);
          ==> demo file.
          A second idea: mouseenter and mouseleave. I have added in the attached file.
          • 2. Re: How can I play a symbol when it reaches a certain position?
            ajguy711 Level 1
            Thank you for the reply! Unfortunately, this isn't quite what I was going for (but could prove useful down the road).
            Say for example I have a symbol positioned at x=80, y=1000. It is set to not autoplay an animation within the symbol. As the user scrolls down the screen, and the symbol begins to move upwards, I want the symbol's animation to play when it reaches a position of y=200. Basically, the symbol's animation would play as it nears the top of the screen while the user scrolls. This is would work on a PC or touch device. Hopefully that clears up what I'm going for.
            • 3. Re: How can I play a symbol when it reaches a certain position?
              jbowden Adobe Employee
              Hi there,
              There is a scroll event for the Stage...you may be able to get what you want using e.pageY within the Stage scroll event.
              hth,
              Joe
              • 4. Re: How can I play a symbol when it reaches a certain position?
                ajguy711 Level 1
                I have found the asnwer at the following discussion: http://forums.adobe.com/message/4909098#4909098
                I've done some modification to the code to allow for multiple symbols to fire. Here's what I've got.
                sym.setVariable("symbolPlayed2", false);
                sym.setVariable("symbolPlayed3", false);
                sym.setVariable("symbolPlayed4", false);
                sym.setVariable("symbolPlayed5", false);
                sym.setVariable("symbolPlayed6", false);
                sym.setVariable("symbolPlayed7", false);
                var mySymbolObject2 = sym.getSymbol("Part2");
                var mySymbolObject3 = sym.getSymbol("Part3");
                var mySymbolObject4 = sym.getSymbol("Part4");
                var mySymbolObject5 = sym.getSymbol("Part5");
                var mySymbolObject6 = sym.getSymbol("Part6");
                var mySymbolObject7 = sym.getSymbol("Part7");
                $(window).scroll(function() {
                    var y_scroll_pos = window.pageYOffset;
                    var scroll_pos2 = 1;
                    var scroll_pos3 = 769;
                    var scroll_pos4 = 1537;
                    var scroll_pos5 = 2305;
                    var scroll_pos6 = 3073;
                    var scroll_pos7 = 3841;
                       if(y_scroll_pos > scroll_pos2) {
                var symbolPlayed2 = sym.getVariable("symbolPlayed2");
                if (!symbolPlayed2) {
                    sym.$("Part2").show();
                    mySymbolObject2.play(0);
                    sym.setVariable("symbolPlayed2", true);
                       if(y_scroll_pos > scroll_pos3) {
                var symbolPlayed3 = sym.getVariable("symbolPlayed3");
                if (!symbolPlayed3) {
                    sym.$("Part3").show();
                    mySymbolObject3.play(0);
                    sym.setVariable("symbolPlayed3", true);
                       if(y_scroll_pos > scroll_pos4) {
                var symbolPlayed4 = sym.getVariable("symbolPlayed4");
                if (!symbolPlayed4) {
                    sym.$("Part4").show();
                    mySymbolObject4.play(0);
                    sym.setVariable("symbolPlayed4", true);
                       if(y_scroll_pos > scroll_pos5) {
                var symbolPlayed5 = sym.getVariable("symbolPlayed5");
                if (!symbolPlayed5) {
                    sym.$("Part5").show();
                    mySymbolObject5.play(0);
                    sym.setVariable("symbolPlayed5", true);
                       if(y_scroll_pos > scroll_pos6) {
                var symbolPlayed6 = sym.getVariable("symbolPlayed6");
                if (!symbolPlayed6) {
                    sym.$("Part6").show();
                    mySymbolObject6.play(0);
                    sym.setVariable("symbolPlayed6", true);
                       if(y_scroll_pos > scroll_pos7) {
                var symbolPlayed7 = sym.getVariable("symbolPlayed7");
                if (!symbolPlayed7) {
                    sym.$("Part7").show();
                    mySymbolObject7.play(0);
                    sym.setVariable("symbolPlayed7", true);
                This all goes in document.compositionReady. Hopefully others find this helpful.
