2 Replies Latest reply on Jul 22, 2014 3:45 AM by Megan Bennett
    business catalyst won't open in dreamweaver
    Uniqorn2009
      When I click the Get Started button or try to open a New Business Catalyst site from the site menu, the dialog box flashes but nothing else happens. I can open it on my other computer, but on my laptop. it's not working. Is there a setting I need to fix or something?
        • 1. Re: business catalyst won't open in dreamweaver
          Alex Pavelescu Adobe Employee
          Hi!
          There are some steps in this doc that should apply to your case: http://forums.adobe.com/docs/DOC-2202
          Try it out and let me know how it goes
          [...] If you still encounter any issue, here are the steps to fix this :
          1. De-activate your DW
          2. Delete the opm.db.
          The opm.db file can be found in the OOBE folder in:
          - on Mac: <yourusername>/Library/Application Support/Adobe
          - onWindows XP: <youruser>\Local Settings\Application Data\Adobe
          - on Windows 7: <youruser>\AppData\Local\Adobe
          3. Re-activate the DW
              You should be able to connect to BC from DW now.
          • 2. Re: business catalyst won't open in dreamweaver
            Megan Bennett
            Hi Alex,
            I have the same problem as reported above.  I have tried the instructions also with activation, deleting the opm.db file and reactivating. No success. What are the next steps I can try?
            I manage my client sites (BC Premium Partner)  by creating them within my partner portal, then FTP down the site locally, then manage the site via Dreamweaver.  I can then edit and publish up or down to BC.  Any ideas? It would be fantastic to be able to create and import from the featured panels within DW.  I can't use any features on the BC Panel (module tags etc), the panel just sits there with the Build and publish business websites and powerful online stores within Dreamweaver." and "Try Adobe Business Catalyst for free today!"
            Thanks Megan
