I would like a set of MC buttons react a certain way on the screen. For this I did not wan to group then into another one MC but decided to make a var with them. However it does not seem to work. Is it possible?
Here is my not working code:
var dimmedLyteRing_arr:Array = new Array(IntroIMGS_COLLAGE.AppsIntro.coolingreflectionsIntro_btn, IntroIMGS_COLLAGE.AppsIntro.towerspectaculaireIntro_btn, IntroIMGS_COLLAGE.AppsIntro.CountryTowerIntro_btn, IntroIMGS_COLLAGE.AppsIntro.FlamelessTabletopAccentsIntro_btn, IntroIMGS_COLLAGE.AppsIntro.SilverBloomIntro_btn, IntroIMGS_COLLAGE.AppsIntro.gazingglowIntro_btn); dimmedLyteRing_arr.buttonMode=true; dimmedLyteRing_arr.useHandCursor = true;
Here is my full version of non working code:
//set up a vars array for a set of images to dim on MOUSE_OVER/OUT
//set up a vars array for a set of images to make dimLyteRing_arr to dim on MOUSE_OVER/OUT
var dimmerLyteRing_arr:Array = new Array(IntroIMGS_COLLAGE.prdctsIntro.LyteRing6SMTIntro_btn);
//var dimLyteRing_Tween:TweenMax = TweenMax.allTo(dimLyteRing_arr, 1, {scaleX:.7, scaleY:.7, colorMatrixFilter:{saturation:.1, brightness:.5}, paused:true});
var dimLyteRing_Tween:TweenMax = TweenMax.to(dimmedLyteRing_arr, .5, {alpha:.5, paused:true});
dimmerLyteRing_arr.addEventListener(MouseEvent.MOUSE_OVER, navOver_dimLyteRing_arr);
dimmerLyteRing_arr.addEventListener(MouseEvent.MOUSE_OUT, navOut_dimLyteRing_arr);
function navOver_dimLyteRing_arr(e:MouseEvent):void{
dimLyteRing_Tween.play();
function navOut_dimLyteRing_arr(e:MouseEvent):void{
dimLyteRing_Tween.reverse();
You can not have a Array listening for MouseEvents.
To be able to listen for MouseEvents an Object has to be a DisplayObject.
What you can do, though, is adding any DisplayObject to an Array, and then looping through the Array and assign your EventListeners individually.
