4 Replies Latest reply on Jan 24, 2013 4:15 PM by romanobstuder
    Hyperlink to a page
    romanobstuder Level 1
      Hi all
      I am trying to link all my images in a document.
      If I recognize the filename and it is a logo (only a limited logos are present) I link to the URL
      All others must link to a given page number.
      The first part works. But I can not figure out how to make the link to a page...
           case "cat 22m95y v1.eps":
                  var myHyperLinkeFrame = myFrame.parent.textFrames.add(myLabelLayer2, undefined, undefined,{geometricBounds : myGreyBoxBounds});
                  myHyperlinkURL = myDocument.hyperlinkURLDestinations.add("www.catfootwear.com");
                  myHyperlinkSource = myDocument.hyperlinkPageItemSources.add(myHyperLinkeFrame);
                  myHyperlink=myDocument.hyperlinks.add(myHyperlinkSource,myHyperlinkURL );
                  myHyperlink.visible=true;
          break;
          default:
                  $.writeln ("myImageJumperPage " + myImageJumperPage );
                  $.writeln ("myImageJumperPage " + Number (myImageJumperPage) );
                  var bla = Number (myImageJumperPage) ;
                  $.writeln ("bla " + bla);
                  myHyperlinkPage = myDocument.hyperlinkPageDestinations.add();
                  myHyperlinkPage.destinationPage.pageNumber = myImageJumperPage;
                  myHyperlink=myDocument.hyperlinks.add(myHyperlinkSource, myHyperlinkPage);
      Any hins appreciated
      Romano
        • 1. Re: Hyperlink to a page
          should add
          this is where things go wrong...
          • 2. Re: Hyperlink to a page
            myHyperlinkPage.destinationPage = "2";
            I also tried this but again no go
            • 3. Re: Hyperlink to a page
              -hans- Level 4
              it expects a whole reference.
              For example:
              myHyperlinkPage.destinationPage = app.activeDocument.pages.item(0)
              • 4. Re: Hyperlink to a page
                OK I get it the reference to a page does not work based on a number as in go to page 10
                Needed to create the reference in "page" terms first.
                            var destPage = myDocument.pages.itemByName(myImageJumperPage.toString());
                This line changes (type cast) the number to a string, then finds the page with that (String)Name and creates a reference.
                I guess this could be coded in a more direct way, but I am happy.
                The code does the job
                Thanks for your help Hans
                            $.writeln ("Found a logo, jump to website 2");
                            var myHyperlinkURL = myDocument.hyperlinkURLDestinations.add("www.catfootwear.com");
                            var myHyperlinkSource = myDocument.hyperlinkPageItemSources.add(myHyperLinkeFrame);
                            var myHyperlink = myDocument.hyperlinks.add(myHyperlinkSource,myHyperlinkURL );
                            myHyperlink.visible = true;
                    break;
                    default:
                            $.writeln ("Found any image, create link to the price list on page: " + myImageJumperPage );
                            var myHyperlinkDestination = myMakeHyperlinkDestination(destPage, myDocument);
                            var myHyperlink = myDocument.hyperlinks.add(myHyperlinkSource, myHyperlinkDestination);
                function myMakeHyperlinkDestination(myDestPage, myDocument){
                    //If the hyperlink destination already exists, use it;
                    //if it doesn't, then create it.
                    try{
                        var myHyperlinkDestination = myDocument.hyperlinkDestinations.item(myDestPage);
                        myHyperlinkDestination.name;
                    catch(myError){
                        myHyperlinkDestination = myDocument.hyperlinkPageDestinations.add(myDestPage);
                        myHyperlinkDestination.destinationPage = myDestPage;
                    //myHyperlinkDestination.name = myDestPage.name;
                    //Set other hyperlink properties here, if necessary.
                    return myHyperlinkDestination;
