6 Replies Latest reply on Jan 24, 2013 10:31 AM by Gustavo Del Vechio
    Pass a function when calling onClick for a button (UI)
    Gustavo Del Vechio Level 3
      Hi
      I´m now studying and adventuring myself in the Script UI creation. I´m enjoying it !!!
      I´m having the following trouble: I added a button to a dialog box and would like to tell script to run some commands when users click on the button. So this is a simple (poor example):
      var dlg = new Window ("dialog", "My dialog", [0,0,0,0])
      dlg.size = [500,500]
      dlg.location = [300,300]
      var b = dlg.add("button", [0,0,0,0], "Run")
      b.location = [20, 180]
      b.size = [80, 30]
      dlg.show()
      b.onClick = test () //the problem is here
      function test(){
        alert("teste")
      Everything is right. But the onClick event does not execute the function test I´m passing! What Am I missing?
      I know if I use
      b.onClick = function (){
      It works...but I´d like the function to be called instead of directlly created when calling the onClick. Do not know if I´m able to explain it better.
      Thank you for the help
      Best Regards
      Gustavo.
