5 Replies Latest reply on Jan 25, 2013 3:37 AM by BEGINNER_X
    Open all .indd files from the selected folder
    BEGINNER_X Level 3
      Hi All,
      I want to open all .indd files from the selected folder.
      Trying script:
      var myFolder = Folder.selectDialog( "Select a folder with InDesign files" );
      var myFiles = [];
      var myFileList = myFolder.getFiles();
      for (var i = 0; i < myFileList.length; i++) {
                var myFile = myFileList[i];
               myFile.name.match(/\.indd$/)
                myFiles.push(myFile);
                app.open(myFiles)
      Can anyone give solution for me.
      Thanks in advance
      BEGINNER
        • 1. Re: Open all .indd files from the selected folder
          MrTIFF Level 3
          var myFolder = Folder.selectDialog("Select a folder with InDesign files");
          if (!myFolder)
            exit(0);
                    if (myFile instanceof File && myFile.name.match(/\.indd$/i)) {
                              app.open(myFile);
          Cheers,
          Stephen
          • 2. Re: Open all .indd files from the selected folder
            Kasyan Servetsky Level 5
            Here is an example of how to open all indd-files from the selected folder and its subfolders.
            var files;
            var folder = Folder.selectDialog("Select a folder with InDesign documents");
            if (folder != null) {
                files = GetFiles(folder);
                if (files.length > 0) {
                    // turn off warnings: missing fonts, links, etc.
                    app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
                    for (i = 0; i < files.length; i++) {
                        app.open(files[i]);
                    // turn on warnings
                    app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
                else {
                    alert("Found no InDesign documents");
            function GetFiles(theFolder) {
                var files = [],
                fileList = theFolder.getFiles(),
                i, file;
                for (i = 0; i < fileList.length; i++) {
                    file = fileList[i];
                    if (file instanceof Folder) {
                        files = files.concat(GetFiles(file));
                    else if (file instanceof File && file.name.match(/\.indd$/i)) {
                        files.push(file);
                return files;
            • 3. Re: Open all .indd files from the selected folder
              There are a couple of conceptual errors in your script, which may be the reason you couldn't get it to work. This line
              does "nothing". It tries to find a match for the variable "myFile", but then it doesn't 'do' anything with the result -- there is no "logic" surrounding the statement. So the next line,
              will always be executed. You probably meant something like
              if (myFile.name.match(/\.indd$/))
              .. Javascript does what it gets told and does not do "what you mean".Next, another error is this:
              app.open(myFiles)
              I had to check this, but you are right: app.open can open an array of files -- I only use it to open just one file at a time. However, you placed this statement inside the main loop! So for every file in the loop, InDesign attempts to open *all* files, again and again.
              With these changes, you can get your original script running properly.
              By the way, note that your question has been answered before. A nice in-depth discussion is in http://forums.adobe.com/thread/791888 -- of particular interest is the entire "when is a file an InDesign file" sub-discussion.
              Here is a line that works ... but I would advise you not to use it. Please try to fix your own script! Only if you understand the basic concepts, then you can advance to this:
              app.open(Folder(Folder.selectDialog( "Select a folder with InDesign files")).getFiles(function(f) { return f instanceof File && !f.hidden && (f.name.match(/\.indd$/i) || f.type.match(/^IDd/)); } ));
              • 4. Re: Open all .indd files from the selected folder
                Kasyan Servetsky wrote:
                Here is an example of how to open all indd-files from the selected folder and its subfolders. ...
                I think I'm not going to try to do that in a single statement ...
                • 5. Re: Open all .indd files from the selected folder
                  BEGINNER_X Level 3
                  Respected Jongware/Kasyan/All
                  Thanks for your immediate response....
                  I created script with the help of forum:
                  var myFolder = Folder.selectDialog("Choose the folder")
                  if(myFolder.length==0)
                      alert("No Folder Selected")
                      exit(0)
                  var myFiles = myFolder.getFiles("*.indd")
                  if(myFiles.length==0)
                      alert("No InDesign files in folder")
                  for(i=0; i<myFiles.length; i++)
                      myFile = myFiles[i]
                      app.open(myFile)
                  Thanks in advance
                  BEGINNER
