4 Replies Latest reply on Jan 27, 2013 10:47 AM by smoothsea
    Controlling table column alignment using variable
    smoothsea Level 3
      Hi I'm new to Javascript, having only used Applescript before.
      I'm using Indesign 5.5 on Mac and I'm learning Javascript by adapting old Applescripts that I have been using for years.
      So, with an existing table, one of the things I want to do is to set the alignments in the columns using a varible. Here's what I've tried so far:
      function setColumnWidthsAndAlignments()
          var myWidths=[29, 23, 13, 13, 13, 13];
          var myAlignments=["leftAlign","leftAlign","centerAlign","centerAlign","rightAlign","rightAlign"];
          var numberOfColumns=myTable.columns.count();
          for (c=0;c<numberOfColumns;c++)
              myTable.columns[c].width=myWidths[c];
              myTable.columns[c].cells.everyItem().texts.everyItem().justification=Justification.myAlignments[c];
      but I get an error
      -- Object does not support the property or method 'myAlignments' --
      If I discard the variable myAlignments and just put leftAlign for example, it works, so maybe I'm not declaring the variable properly?
      I know I could add a few extra paragraph styles and cell styles and style the table that way, but I though this would be a good learning exercise (besides which I want to limit the number of paragraph styles in the document - there are enough already!)
      If anybody is really interested, I'd like to place the whole script here and would really welcome any feedback on how the structure could be improved or optimised or just tell me if I'm heading in the right direction.
      Thanks and regards,
      Malcolm
      //Simple table script 1
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll; //make sure that user interactivity is switched on ????  why????
      if(checkForOpenDocs()) //checks to see if there are any open Indesign documents
              if(targetMyTable()) //checks to see if the selection is inside a table - if not, gives an error dialog - if it is, returns variable myTable which can be used to target different parts of the table
                     // selectLastRow();
                      //resetTable();
                      //applyTableTextParaStyle();
                      //removeRules();
                      //applyAlternatingFills();
                      setColumnWidthsAndAlignments();
                      //setRowHeightsAndInsets();
      function checkForOpenDocs()
          if (app.documents.length!=0)   //there is at least one document open
              myDocument = app.documents.item(0);    //get the id of the frontmost document - might be useful?
              return true;
          else
              alert("There are no documents open");
              return false;
      function targetMyTable() //no matter what is selected in the table, change selection to be whole table
          if(app.selection[0]==null) //if there is nothing selected
              alert("There is nothing selected.");
              return false
          var mySelection = app.selection[0];
          switch(mySelection.constructor.name)
                                              //When a row, a column, or a range of cells is
                                              //selected, the type returned is always "Cell"
              case "Cell":
              myTable=mySelection.parent;
              return true
              break;
              case "Table":
              myTable=mySelection;
              return true
              break;
              case "InsertionPoint":
              case "Character":
              case "Word":
              case "TextStyleRange":
              case "Line":
              case "Paragraph":
              case "TextColumn":
              case "Text":
              if(app.selection[0].parent.constructor.name == "Cell")
                  myTable=mySelection.parent.parent;
                  return true
              else
                  alert("The selection is not inside a table.");
                  return false
              break;
              case "Rectangle":
              case "Oval":
              case "Polygon":
              case "GraphicLine":
              case "TextFrame":
              if(app.selection[0].parent.parent.constructor.name == "Cell")
                  myTable=mySelection.parent.parent.parent;
                  return true
              else
                  return false
              break;
              case "Image":
              case "PDF":
              case "EPS":
              if(app.selection[0].parent.parent.parent.constructor.name == "Cell")
                  myTable=mySelection.parent.parent.parent.parent;
                  return true
              else
                  return false
              break;
              default:
              break;
      function resetTable()
          myTable.cells.everyItem().clearCellStyleOverrides (true);
      function selectLastRow()
          //myTable.cells.itemByRange(0,-1).select();
          myTable.rows.itemByRange(-1,-1).select();
      function applyTableTextParaStyle()
          myParagraphStyle=myDocument.paragraphStyles.item("•table text");
          myTable.cells.everyItem().texts.everyItem().appliedParagraphStyle = myParagraphStyle;
      function removeRules()
          myTable.cells.everyItem().topEdgeStrokeWeight=0;
          myTable.cells.everyItem().bottomEdgeStrokeWeight=0;
          myTable.cells.everyItem().leftEdgeStrokeWeight=0;
          myTable.cells.everyItem().rightEdgeStrokeWeight=0;
      function applyAlternatingFills()
          myColor=myDocument.swatches.item("Black");
          myTable.alternatingFills=AlternatingFillsTypes.alternatingRows;
          myTable.startRowFillColor=myColor;
          myTable.startRowFillTint=20;
          myTable.endRowFillColor=myColor;
          myTable.endRowFillTint = 0;
      function setRowHeightsAndInsets()
          myTable.rows.everyItem().minimumHeight=1.058;
          myInset=0.5;
          myTable.rows.everyItem().topInset=myInset;
          myTable.rows.everyItem().bottomInset=myInset;
        • 1. Re: Controlling table column alignment using variable
          -hans- Level 4
          welcome
          myAlignments should be properties, not strings. didn't read the second part of your post ..
          myTable = app.activeDocument.stories[0].tables[0];
          setColumnWidthsAndAlignments(myTable)
          function setColumnWidthsAndAlignments(tableObj)
              var myAlignments=[Justification.LEFT_ALIGN,Justification.LEFT_ALIGN,Justification.CENTER_ALIGN,Justification.CENTER_ALIGN,Justification.RIGHT_ALIGN,Justification.RIGHT_ALIGN];
              var numberOfColumns=tableObj.columns.count();
                  myTable.columns[c].cells.everyItem().texts.everyItem().justification=myAlignments[c];
          • 2. Re: Controlling table column alignment using variable
            TᴀW Adobe Community Professional & MVP
            You'd probably have more luck trying something like:
            var myAlignments = [Justification.LEFT_ALIGN, Justification.LEFT_ALIGN,
            Justification.CENTER_ALIGN etc.]
            and then in the other line: ...texts.everyItem().justification =
            myAlignments[c];
            Alternatively, you could try keeping it as you have it, but perhaps
            changing it to this:
            texts.everyItem().justification = eval("Justification."+myAlignments[c]);...
            which just creates a string and then runs it with eval.
            At any rate, the problem as I see it with what you have is that you
            myAlignments is an array of strings, and you cannot access a property of
            an object (in this case Justification) with a dot+string. When you put
            "Justification.leftAlign" and it works, I think that's because leftAlign
            isn't acting as a string -- it's simply a property of the Justification
            object.
            Ariel
            • 3. Re: Controlling table column alignment using variable
              (Hans beat me to it!)
              • 4. Re: Controlling table column alignment using variable
                smoothsea Level 3
                Perfect! - that's great. Thank you very much Hans.
                Arīel - I didn't understand the eval statement when I tried to use the variable not as string (if that makes sense).
                Now you've explained it, it all makes sense - thank you!
                Regards,
                Malcolm
