I have a search results page that has been giving me a headache for a few weeks now lol. I have the following SQL to filter what the user is looking for with the search engine. Everything works fine UNTIL i sort the results by province. When i do so i get sereval unwanted image links. For example. If i get 7 results when i sort by ON (ontario) and 1 out of the 7 pets has an image which gives the word "image" repeating 7x based on the sort result and only 1 of those links actually work. Not sure why the others are appearing. I know it's because of the ORDER BY i have in the SQL, because when i remove the order by it works prefectly. I searched all over to find someone else with somewhat of a similar problem, but no go. Looked at my sql reference book and still nothing. Now sure whats wrong. Hope someone can see something i can't.
------ SQL for search engine -------
<cfquery name="qSearch" datasource="#APPLICATION.dataSource#">
SELECT PetID, PetName, PetType, PetStatus, PetGender, Province, City, MyPetID, PostDate, PetBreed, ImageName
FROM PetFind
WHERE 0=0
AND (PetName = '#Search#' OR MyPetID LIKE '%#Search#%')
<cfif IsDefined('URL.Province')>
AND Province = <cfqueryparam value="#URL.Province#" cfsqltype="cf_sql_varchar">
ORDER BY City
ASC
</cfif>
</cfquery>
------ Image link (popUp) ------
<a href="javascript:popImage('../pimages/#URLEncodedFormat(qSearch.ImageName)#.jpg','Picture of #qSearch.PetName#')" onLoad="window.location.href=window.location.href"> | |
Image | |
</a> |
What's the code you're using for looping over the recordset and outputting the image links?
I found the problem because you asked about the outputting. I had 2 cfoutputs when i only needed the 1. So thanks for the reply it helped alot and saved me future headaches on this issue. lol
Cheers
