5 Replies Latest reply on Jan 9, 2014 7:31 AM by dkgraft
    How to code URL Links to a pdf on my computer
    kratistoss
      Hi!
      Im prepping a presentation/website where i need to link a pdf file (on my computer) to a small text i have on the stage.
      I tried with some variations in the code (wether with the .pdf extension or not, removing underscores in name), but it simply will not react in any way.
      When i prep the code for linking to a website...i have no problem, it works perfectly.
      Please tell me this isnt a limit in Edge....i have put so much work on this project, and i need to link those .pdf's
      thanks in advance for your time and help
      Krati
        • 1. Re: How to code URL Links to a pdf on my computer
          TimJaramillo Level 4
          Hi there,
          3 questions:
          1. to clarify- you have a text link, and on click of that link you want to show a pdf in the same/new window, yea?
          2. is the pdf file in the same directory as your Edge files, or nested deeply somewhere else on your hard drive?
          3. are you on a mac or PC?
          • 2. Re: How to code URL Links to a pdf on my computer
            jbowden Adobe Employee
            Hey there,
            It's a browser limitation for JavaScript to open your file if your HTML is hosted online - opening local files via JavaScript is considered a security risk and is not allowed.
            However, if you're loading your HTML locally, you should be able to open a PDF locally. Here's some code I just tested that works (you must save your project, and then open the HTML file from the Finder/Explorer level):
            window.open("/users/username/desktop/myfile.pdf");
            But as I mentioned, if you host your HTML and required files (or if you try to Preview in Browser from Edge Animate), then this code will not work due to built-in browser security. If you intend to host your HTML online, then your PDF files would have to be online as well.
            hth,
            Joe
            • 3. Re: How to code URL Links to a pdf on my computer
              kratistoss Level 1
              Thank you for the fast reply.....
              I managed to confirm most of what you said Joe. I am now running the .pdf's from the same folder the actual edge file is in, and works fine, even if prompted from edge with cntrl+enter.
              Thank you both for the info and tips
              It is very appreciated
              And a special thanks to jaramillo for having helped a second time in my learning of Edge
              • 4. Re: How to code URL Links to a pdf on my computer
                I'm glad to be of help!
                • 5. Re: How to code URL Links to a pdf on my computer
                  dkgraft Level 1
                  I just ran into a similar issue but thought I would share. I'm building an edge project for use in a DPS app. I wanted to have buttons that open PDFs in the in-app browser. So here is what I did.
                  create a pdf folder in the folder with your edge file.
                  place all of your pdfs in this folder.
                  then, in animate, code the button "click" event with the following.
                  window.open("pdf/file_name.pdf","_blank");
                  Hope this helps.
                  - Dylan
