11 Replies Latest reply on Aug 13, 2013 3:38 PM by tusharde
    Finding column position
    Lucky Siva Level 1
      Suppose, in a two-column textframe, how to find whether a particular word or something is in the first or second column using Indesign javascript?
        • 1. Re: Finding column position
          -hans- Level 4
          var myTextSel = app.selection[0],
          columnContentOfSel = myTextSel.textColumns[0].texts[0].contents,
          myParentTextFrames = myTextSel.parentTextFrames;
          for(var i = 0; i < myParentTextFrames.length; i++){
              myColumn = 1;
              var currTf = myParentTextFrames[i];
              for(var c = 0; c < currTf.textColumns.length; c++)
          if(columnContentOfSel == currTf.textColumns[c]. texts[0].contents)
              alert('column: ' + myColumn);
              exit();
                  myColumn = myColumn + 1
          let's start from any textselection.
          This'll give you the startcolumn of it.
          There may be better solutions
          • 2. Re: Finding column position
            Lucky Siva Level 1
            Great Hans,
            Many thanks for your answer. I had been searching for properties and methods in the Object Model.
            • 3. Re: Finding column position
              -hans- Level 4
              thx
              you may also compare horizontalOffset and / or insertionPoints[0] ... + any other property which is relevant.
              Happy scripting
              Hans
              • 4. Re: Finding column position
                Peter Kahrel Adobe Community Professional & MVP
                That can be done easier:
                var myTextSel = app.selection[0];
                if (myTextSel.index < myTextSel.parentTextFrames[0].textColumns[1].insertionPoints[0].index){
                    // we're in column 1
                } else {
                    // we're in column 2
                myTextSel.index returns the index of the first insertionPoint of myTextSel. If you compare that with the index of the first insertionPoint of column 2, you know in which column the text selection is.
                Peter
                • 5. Re: Finding column position
                  Haha - Hans posted a clue while I was at it.
                  • 6. Re: Finding column position
                    Lucky Siva Level 1
                    Superb Peter,
                    These are really helpful. I will try to modify it so that it can work for customised number of columns, say, one, two or three.
                    • 7. Re: Finding column position
                      tusharde
                      Hi Lucky Siva,
                      I ran across this post while searching for a solution to finding the column position of the text. Did you ever find a solution for customized number of columns?
                      Would love to hear the solve.
                      -Tushar
                      • 8. Re: Finding column position
                        Jump_Over Level 5
                        try this as a solution:
                        var mBegin = app.selection[0].insertionPoints[0],
                             mFrame = mBegin.parentTextFrames[0],
                             fBegin = mFrame.insertionPoints[0],
                             sBegin = mBegin.parentStory.insertionPoints[0],
                             mColumns = mBegin.parentStory.insertionPoints.itemByRange(sBegin, mBegin).texts[0].textColumns.length,
                             fColumns = mFrame.insertionPoints.itemByRange(fBegin, mBegin).texts[0].textColumns.length,
                             sFrames = mBegin.parentStory.textContainers.length,
                             mFrames = mBegin.parentStory.insertionPoints.itemByRange(sBegin, mBegin).texts[0].parentTextFrames[0].length;
                        alert("Selection starts\rat column: " + fColumns + " (" + mColumns + " in entire story)\r" + "in a frame no: " + mFrames + " (from " + sFrames + ")");
                        Jarek
                        • 9. Re: Finding column position
                          tusharde Level 1
                          That is awesome. Thanks Jarek. Works perfectly.
                          • 10. Re: Finding column position
                            tusharde Level 1
                            Hi Jarek,
                            I applied the above solution to my script. But in some instances of using the script i am running across this error. This usually happens in documents with lot of pages where the paragraph style has been applied to a few text frame. While i dont think that should be a problem, I am not able to find the exact reason for this issue. Would you happen to have any clue?
                            Thanks for your help again
                            -Tushar
                            • 11. Re: Finding column position
                              tusharde Level 1
                              Here my complete code for reference:
                              main();
                              function main() {
                                 var doc = app.activeDocument;
                                 var sel   = doc.selection;
                                 var frame = sel[0];
                                 var story;
                                 var charStyleNames = doc.characterStyles.everyItem().name;
                                 var chosen_cStyle;
                                 var arr=[];
                                 var textFrameXpos = app.selection[0].geometricBounds[1];
                                 var currPara = app.selection[0].paragraphs[0]
                                 var textPointSize = currPara.pointSize;
                                 var longestDialogue;
                                 var tabStopPos;
                                 if (frame && frame.constructor.name === "TextFrame") {
                                    story = frame.parentStory;
                                 } else {
                                    throw "No text frame selected";
                                 if (currPara.appliedParagraphStyle.index == 0 || currPara.appliedParagraphStyle.index == 1) {
                                    throw "Please assign a new Paragraph Style to this text. Changing properties of the Root Paragraph Style or Basic Paragraph Style is not recommended.";
                                 //Scales frame if the text is overset.
                                 if(story.overflows) {
                                    sel[0].fit(FitOptions.FRAME_TO_CONTENT);
                                 // Create dialog box
                                 dialogBox = app.dialogs.add({name:"Indent Preferences", canCancel:true});
                                 with(dialogBox)
                                    with(dialogColumns.add())
                                       with(dialogRows.add())
                                          staticTexts.add ({ staticLabel:"Select a Character Style to apply to the dialog"});
                                                staticTexts.add ({ staticLabel:"Character Style"});
                                             with (dialogColumns.add())
                                                var dd_charStyle = dropdowns.add({stringList:charStyleNames, selectedIndex:0})
                                 if (!dialogBox.show())
                                    dialogBox.destroy();
                                    exit(0);
                                 chosen_cStyle = doc.characterStyles.item(dd_charStyle.selectedIndex);
                                 if (chosen_cStyle.index != 0) {
                                    runBasicGrep(story);
                                    charStyleGrep(story);
                                    setTab();
                                 } else {
                                    setTab();
                                 function runBasicGrep(story) {
                                    // Reset the Find/Change options
                                    app.findGrepPreferences = NothingEnum.nothing;
                                    app.changeGrepPreferences = NothingEnum.nothing;
                                    // Indent script dialogue
                                    app.findGrepPreferences.findWhat = ":((\\t+)?(\\s+)?)?";
                                    app.changeGrepPreferences.changeTo = ":\\t~i";
                                    story.changeGrep();
                                    // Fix the TV:30 indenting.
                                    app.findGrepPreferences.findWhat = "(?i)(tv)(\\s*?):(\\s*?)(\\d+)";
                                    app.changeGrepPreferences.changeTo = "$1:$4";
                                    story.changeGrep();
                                    //Fix the http web url break
                                    app.findGrepPreferences.findWhat = "(http|ftp|https)(\\s*?)(:)(\\s*?)(\\/\\/[\\w\\-_]+(\\.[\\w\\-_]+)+([\\w\\-\\.,@?^=%&amp;:/~\\+#]*[\\w\\-\\@?^=%&amp;/~\\+#])?)";
                                    app.changeGrepPreferences.changeTo = "$1$3$5";
                                    story.changeGrep();
                                 function charStyleGrep(story) {
                                    // Apply the character style only to dialog. Avoids the "TV:30" or web urls.
                                    app.findGrepPreferences.findWhat = "^(?!(?i)tv\\s*?:\\s*?\\d+)(?!(http|ftp|https)(\\s*?)(:)(\\s*?)(\\/\\/[\\w\\-_]+(\\.[\\w\\-_]+)+([\\w\\-\\.,@?^=%&amp;:/~\\+#]*[\\w\\-\\@?^=%&amp;/~\\+#])?)).+:.+";
                                    app.changeGrepPreferences.changeTo = "";
                                    app.changeGrepPreferences.appliedParagraphStyle = app.selection[0].paragraphs[0].appliedParagraphStyle;
                                    app.changeGrepPreferences.appliedCharacterStyle = chosen_cStyle;
                                    story.changeGrep();
                                 // if (frame && frame.constructor.name === "TextFrame") {
                                 //    story = frame.parentStory;
                                 // } else {
                                 //    throw "No text frame selected";
                                 function setTab() {
                                    app.findGrepPreferences = app.changeGrepPreferences = null;
                                    app.findGrepPreferences.findWhat = ":((\\t+)?(\\s+)?)?";//type the product code here
                                    found = app.activeDocument.findGrep (true);
                              // Search for all the dialogue characters and store in an array
                                    if(found.length>0)
                                        for (j = 0; j < found.length; j++)
                                            found[j].select();
                                             // alert("Selection starts\rat column: " + fColumns + " (" + mColumns + " in entire story)\r" + "in a frame no: " + mFrames + " (from " + sFrames + ")");
                                              var mFramePosX = mFrame.geometricBounds[1],
                                                currColWidth = mFrame.textFramePreferences.textColumnFixedWidth,
                                                currGutterWidth = mFrame.textFramePreferences.textColumnGutter;
                                                currGrepSelPos = app.selection[0].characters[0].horizontalOffset,
                                                dialoguePos = currGrepSelPos - (mFramePosX + (currColWidth * (fColumns - 1)) + ( currGutterWidth * (fColumns - 1)));
                                              arr.push(dialoguePos);
                                    else
                                        alert("false");
                              // Check which of the elements in the array is the longest dialogue.
                                    longestDialogue = arr[0];
                                    for (var i = 0; i < arr.length; i++) {
                                       if(arr[i]>longestDialogue) {
                                          longestDialogue = arr[i];
                              // Calculate the tabStopPos
                                    tabStopPos = longestDialogue + (textPointSize/2);
                              // Check if there is tab stop. Reassign value to it. Else create a new tabstop.
                                    if (currPara.appliedParagraphStyle.tabStops[0] != null) {
                                       currPara.appliedParagraphStyle.tabStops[0].alignment = TabStopAlignment.LEFT_ALIGN;
                                       currPara.appliedParagraphStyle.tabStops[0].position = tabStopPos;
                                    } else {
                                       currPara.appliedParagraphStyle.tabStops.add({alignment:TabStopAlignment.LEFT_ALIGN, position:tabStopPos});
                              // Reset document selection and tool.
                                 doc.select(NothingEnum.NOTHING);
                                 app.toolBoxTools.currentTool = UITools.SELECTION_TOOL;
