1 Reply Latest reply on Jan 28, 2013 8:12 PM by Vikram@Adobe
    Presenter Video Creator (v8)
    MichaelD443 Level 1
      Opened a project. Changed branding to custom. Specifice just a starting branding element. Published, closed, went to EOJ.
      Opened a different project. Can't change branding to end--all check boxes grayed. Can't specify a new custom branding theme. Can select standard branding but it still only shows up in the beginning, can't change to end (or background).Also, now it only uses the custom branding I created and used for the beginning of the other project.
      Is there a cache that must be cleared?
      Thanks. --Michael
        • 1. Re: Presenter Video Creator (v8)
          Vikram@Adobe Level 1
          Hi MichaelD443,
          I followed your steps:-
          opened a project
          changed branding to custom
          specified a starting branding video
          clicked on close project button
          opened a new project.
          goto themes.
          Can select any default themes or change the starting/end video.
          In my case the themes dropdown is enabled and is working fine on my system.
          Are the steps same as yours?
          If the steps are same, then it's a system specific issue.
          You can send us(vikrakum@adobe.com) the diagnostic log with steps mentioned to reproduce the issue.
          There is workaround to get ride of your issue. Close Video Creator. Delete preferences.xml file from this location -> C:\Users\<username>\AppData\Local\Adobe\Presenter Video Creator 8.1\ . Open VC
          Adobe Presenter Engg. Team
