9 Replies Latest reply on Jan 29, 2013 2:19 AM by Peter Spier
    Indesign cs5.5 crashes on startup
    DeborahStewart
      Please Help
      Indesign cs 5.5 was working , I upgraded laptop since last use
      I tried opening old file, and also just opening program and
      Last message that flashes before crash is initializing plugins
      I upgraded to version below to see if that was the problem
      I have read forums but am quite confused
      Using Macbook pro Rentinal 10.8.2
      CS 5.5 version 7.5.3.333
      Crash report is at
      http://pastebin.com/raw.php?i=V5WcxvJs
      Thank you for your assistance
      Deborah
        • 2. Re: Indesign cs5.5 crashes on startup
          DeborahStewart Level 1
          Thank you so much for your assistance
          - there is no Sing in that place listed on the help
          Mac OS: [Startup Disk]/Library/Applications Support/Adobe/SING/Mark II/Datastore
          only has the following folder options
          acrobat
          Adobe illustrator cs2
          colour
          fonts
          Linguistis
          Updater
          I searched for Sing on my hard drive and there is something called Sing.indesign plugin listed at
          applications\ adobeindesign cs5.5\ plugins \ text \Sing.IndesignPlugin
          I tried to remove this but it just removed a copy and the problem persisted
          also managed to send that file to trash but problem also persisted
          thaks again
          Deborah
          • 3. Re: Indesign cs5.5 crashes on startup
            Cut the plugin file, then paste to the desktop rather than dragging, or just delete it.
            • 4. Re: Indesign cs5.5 crashes on startup
              Have deleted file from that place and problem persists - thanks
              • 5. Re: Indesign cs5.5 crashes on startup
                The crash is definitely SING...
                Are you showing hidden files? Not sure if the SING folder would be hidden.
                • 6. Re: Indesign cs5.5 crashes on startup
                  How do you show hidden files?
                  I tried using terminal when I read an earlier reply to another forum post but when I typed in the commands nothing happens - is there a step by step for dummies on how to show hidden files - most instructiosn presume a level of knowledge I do not have
                  thanks
                  • 7. Re: Indesign cs5.5 crashes on startup
                    Best I can offer is Access hidden user library files | Mac OS 10.7 Lion
                    While I know the crash you reported is caused by SING, I'm a Windows user, so my ability to get into the nitty gritty of file structure on your Mac is a little limited.
                    Having delete the SING plugin, you might want to check another crash report and verify that the crashed thread section looks the same. There's a helpful article on reading crash reports at Guide to Interpreting InDesign Crash Reports | InDesignSecrets
                    • 8. Re: Indesign cs5.5 crashes on startup
                      Hi
                      I did not know about hidden files
                      I have now found the hidden file
                      there was no file called datastore - in the hidden library there was Sing/markII/AssocCache
                      I have taken out and trashed the whole SING folder
                      I have also tried just remving the markII
                      The problem persists
                      this is the new crash record
                      http://pastebin.com/raw.php?i=0ruN909k
                      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                      0   dyld                               0x8feab8d3 ImageLoader::isLinked() const + 11
                      1   dyld                               0x8fea94d3 NSLinkModule + 102
                      2   libdyld.dylib                      0x97723303 NSLinkModule + 87
                      3   com.adobe.InDesign.Font Manager     0x136d8bc8 TINglue_version + 792
                      4   com.adobe.InDesign.Font Manager     0x136d95cf TIN_Startup + 177
                      5   com.adobe.InDesign.Font Manager     0x1365f329 GetPlugIn + 17705
                      6   ObjectModelLib.dylib               0x011381a1 0x111f000 + 102817
                      7   ObjectModelLib.dylib               0x01138abb 0x111f000 + 105147
                      8   ObjectModelLib.dylib               0x01147396 0x111f000 + 164758
                      9   ObjectModelLib.dylib               0x01157c1d ShuksanInit(IStartupScreen* (*)(), IPlugIn*) + 23101
                      10  ObjectModelLib.dylib               0x01153244 ShuksanInit(IStartupScreen* (*)(), IPlugIn*) + 4196
                      11  com.adobe.InDesign                 0x00002842 main + 82
                      12  com.adobe.InDesign                 0x000027c6 start + 54
                      I have searched for tinglue and
                      Shuksaninit but cannot find files called this
                      Also have tried setting up a new user and logging in as new user and then opening indesign - program crashes on launch again.
                      changed language settings - still happened
                      found old software disc and uninstalled and reloaded - FINALLY it has loaded
                      Thanks for your input
                      • 9. Re: Indesign cs5.5 crashes on startup
                        Glad you have it working.
