2 Replies Latest reply on Jan 30, 2013 4:15 AM by [Jongware]
    Export pages to jpg with custom filenames
    d_mancini
      Hi everyone,
      I have found – and slighty edited – this script that exports each InDesign page to jpg, naming it with the relative page number.
      I need to assign to the filename the value of a text that I have placed in each page, that is styled with a paragraph style named "filename".
      It also would be nice to have filenames web-friendly, replacing spaces with dashes and transforming to lowercase.
      Thanks in advance for your help.
      if (app.documents.length != 0) {
          MakeJPEGfile();
      else{
           alert("Please open a document and try again.");
      function MakeJPEGfile() {
           for(var myCounter = 0; myCounter < myDoc.pages.length; myCounter++) {
                if (myDoc.pages.item(myCounter).appliedSection.name != "") {
                     myDoc.pages.item(myCounter).appliedSection.name = "";
                var myPageName = myDoc.pages.item(myCounter).name;
                app.jpegExportPreferences.jpegQuality = JPEGOptionsQuality.high; // low medium high maximum
                app.jpegExportPreferences.exportResolution = 72;
                app.jpegExportPreferences.jpegExportRange = ExportRangeOrAllPages.exportRange;
                app.jpegExportPreferences.pageString = myPageName;
                var myFilePath = "~/Desktop/" + myPageName + ".jpg";
                var myFile = new File(myFilePath);
                myDoc.exportFile(ExportFormat.jpg, myFile, false);
        • 1. Re: Export pages to jpg with custom filenames
          dulajun Level 2
          This code is the same as above but with some modification and a new fuction
              MakeJPEGfile();
          else{
                    var myJpegPrefix = "";
                    var isStyleExist = true;
                    //Checking the existing of the paragraph style (filename)
                    try {
                        myDoc.paragraphStyles.item("filename");
                    catch (myError) {
                        isStyleExist = false;
                    if (isStyleExist)
                      myJpegPrefix = getParagraphContent(myDoc.paragraphStyles.item("filename"), myDoc.pages.item(myCounter)) + myPageName;
                    var myFilePath = "~/Desktop/" + myJpegPrefix + ".jpg";
          // The new function, but needs to add checking the file name rules.
          function getParagraphContent (paragraphStyle, currentPage) {
              var paragraphContent = "";
              for (var c = 0; c < currentPage.textFrames.length; c++) {
                  for (var i = 0; i < currentPage.textFrames.item(c).paragraphs.length; i++){
                      if (currentPage.textFrames.item(c).paragraphs.item(i).appliedParagraphStyle == paragraphStyle) {
                          paragraphContent = currentPage.textFrames.item(c).paragraphs.item(i).contents;
                          return paragraphContent;
          Missed checking the file naming rules.
          • 2. Re: Export pages to jpg with custom filenames
            Abdulaziz Junaid wrote:
            [..] Missed checking the file naming rules.
            Something like this:
                var paragraphContent = null;
               // Remove spaces and returns at the end:
                            paragraphContent = paragraphContent.replace(/\s+$/, '');
               // Replace remaining spaces with hyphen:
                            paragraphContent = paragraphContent.replace(/\s+/g, '-');
               // Make lowercase:
                            paragraphContent = paragraphContent.toLowerCase();
            It does not check for any other illegal characters ((back)slashes, asterisk, question mark, colons, semicolons) -- and neither for ill-advised characters (anything else than plain ASCII such as accented characters or en-dashes). While possible, it's best to avoid this right from the start, rather than relying on the script to remove them or replace with something harmless.
