2 Replies Latest reply on Jan 29, 2013 3:16 AM by ncsdpr123
    in administrator mode drag n drop does not work
    ncsdpr123
      when i run my photoshop cs5 in administrator mode using "run as Administrator ... ", drag and drop does not work.
        • 1. Re: in administrator mode drag n drop does not work
          And specifically? I see no problem. Just running as admin doesn't elevate the privileges/ permissions of anything else. It realyl only runs the process as admin, but if your user does not have access to files otherwise or does not run with teh same privilege level, Windows' security model will prevent processes in different contexts from interacting in such a manner. Perfectly normal.
          Mylenium
          • 2. Re: in administrator mode drag n drop does not work
            ncsdpr123 Level 1
            This is related to my current project in visual basic 2010 express edition and Windows 7 (32bit).
            1. My application always run in administrator mode.
            2. In this application i used createobject("Photoshop.Application") method to reference and run scripts directly from program.
            3. When i run Photoshop in normal mode, error is thrown as can't create ActiveX connection.
            4.Why ?
