2 Replies Latest reply on Nov 15, 2007 10:25 AM by Lonno7
    Need to find RoboEngine
      Hi, All!
      I'm working on a project to try to use merged projects in RoboHelp; the book I have (Version X4) says that "The Systems Administrator must check that the Internet Information Services is installed on the same computer on which RoboEngine is installed." I've looked for RoboEngine, but can't seem to find it. Also, how do I find the IIS?
        • 1. Re: Need to find RoboEngine
          RoboColum(n) Level 5
          Hi Lon.
          IIS is a component of Windows. You'll need to go into your PC's Control Panel and load this windows component. However you do not need to have IIS installed for merged help unless you are using the RoboEngine - it has now been renamed RoboHelp Server BTW.
          So what is the difference I hear you ask? RoboHelp is used to create, compile and publish help output. One of the outputs is Webhelp and is designed for posting on intranets, websites, etc. RoboEngine is a separate product that uses the WebHelp Pro output from RoboHelp to publish to a central server from where users access the help.
          In summary. If all you want to do is output your help to a user's PC or a website, you do not need RoboEngine (aka RoboHelp Server). Hope this helps.
          • 2. Re: Need to find RoboEngine
            Lonno7 Level 1
            Well, Coum,
            That was quick -- and helpful, too. Thanx!
