3 Replies Latest reply: Feb 12, 2013 6:40 AM by SFS-DPS RSS
    PDF Article with HTML Animation
    SFS-DPS Community Member
      Hi all,
      Is it possible to have a article in pdf format but have the HTML animation from Adobe edge appear in better resolution?
      Currently to get the Animation to appear with transparent background I have to build the article as a JPG, PNG article.
      Is this right?
        • 1. Re: PDF Article with HTML Animation
          abuewaida Community Member
          u can have html animation inside pdf folio. Note web content overlays are not resampled which means when u zoom in ur animation will look pixelated.
          Does not matter as long as the original edge animation comes with transparent background.
          • 2. Re: PDF Article with HTML Animation
            Ok. So if i want my edge animation to look good on ipad SD and HD I double the size of the assets resolution. Should the stage in Edge be 1024x768? or 2048x1536?
            Also you say web content? I am currently placing an OAM file in to indesign are you suggesting that i should be linking to the HTML file instead of the OAM? or does it matter?
            • 3. Re: PDF Article with HTML Animation
              If I build the Stage at HD size and place HTML or OAM and click fit web content to frame it still appears to big. Need it to work on SD folio size but appear well in HD also. Any suggestions?
