15 Replies Latest reply on Nov 8, 2013 1:47 PM by bbulla1
    VBA Code error with Adobe Acrobat 10 Type Library
    bbulla1 Level 1
      I have some code I created in Word VBA to combine several separate PDFs into a single PDF.  The code works fine with the Adobe Acrobat 9.0 Type Library and Adobe Reader 9.0 installed.
      But, with the Adobe Acrobat 10 Type Library and Adobe Reader 10 installed, the code fails at the marked code below.  Any suggestions??
          Dim acrobatApp As Acrobat.acroApp
          Set acrobatApp = CreateObject("AcroExch.App")
          Dim mainPDF As Acrobat.AcroPDDoc
          Set mainPDF = CreateObject("AcroExch.PDDoc")  ****THIS IS WHERE THE CODE STOPS WITH A "TYPE MISMATCH" ERROR****
          Dim nextPage As Acrobat.AcroPDDoc
          Set nextPage = CreateObject("AcroExch.PDDoc")
          Dim numPages As Integer
          'Loop through all selected VLS, and add each one to the end of the main PDF
          For i = 0 To lstSelected.ListCount - 1
              mainPDF.Open CurDir & "\" & Replace(ThisDocument.Name, ".doc", "") & ".pdf"
              numPages = mainPDF.GetNumPages
              nextPage.Open lstSelected.List(i)
              If mainPDF.InsertPages(numPages - 1, nextPage, 0, nextPage.GetNumPages, True) = False Then
                  MsgBox "Cannot insert pages"
              End If
              If mainPDF.Save(PDSaveFull, CurDir & "\" & Replace(ThisDocument.Name, ".doc", "") & ".pdf") = False Then
                  MsgBox "Cannot save"
              End If
              'MsgBox lstSelected.List(i)
              nextPage.Close
          Next i
