3 Replies Latest reply on Jan 29, 2013 12:41 PM by WolfShade
    upload files in form
    TheScarecrow Level 1
      Hey I have a form that uploads a file.  I am having trouble with some of the code and hoping someone can help.
      FORM FIELD
      <tr>
                                <td><strong>Upload Submission</strong></td>
                          <td><input
                                                        type="file"
                                                        name="submission"
                                                        id="submission"
                                                        value="#FORM.submission#" class="submissionclass"
                                                        /></td>
                      </tr>
      on submission of the form this code runs
      PROCESSING CODE:
      <cfif FORM.submission EQ " ">
                        <cfset errors = Errors & "<li>Only PDF, DOC, and DOCX file formats are accepted</li>">
              </cfif>
                          <cfif FORM.submission NEQ " ">
                        <cfif #right(#FORM.submission#, 4)# NEQ "docx" OR #right(#FORM.submission#, 3)# NEQ "doc" OR #right(#FORM.submission#, 3)# NEQ "pdf">
                        </cfif>
              </cfif>
      The questions is will this work or do I have to do it another way.
        • 1. Re: upload files in form
          WolfShade Level 4
          Why bother with the conditional if both cases result in errors being set to the warning of "only certain file formats are accepted"?
          Also, <cfif #right(#form.submission#,4)# is slowing you down.  The #'s are used inside strings or CFOUTPUTs.  The line S/B <cfif right(form.submission,4)
          Actually, instead of using right(), use listGetAt(form.submission,len(form.submission),"."), this will split the filename into a period-delimited list, getting the last list element (the file extension) for comparison.
          Just my $0.02
          ^_^
          • 2. Re: upload files in form
            yea... I just upload the file and check it and then delete it if there is a problem.or not the right file type.
            • 3. Re: upload files in form
              WolfShade Level 4
              Correction: listGetAt(form.submission,len(form.submission),".") should be listGetAt(form.submission,LISTLEN(form.submission),".")
              ^_^
