1. Re: Extract Filter?
Curt Y Jan 29, 2013 8:21 AM (in response to SusanSherman)There are many better options to the extract tool. Here is a good tutorial on one way to do this.
http://tv.adobe.com/watch/the-russell-brown-show/masking-basics-in-photoshop-cs5/
2. Re: Extract Filter?
conroy Jan 29, 2013 8:25 AM (in response to SusanSherman)Now there is Refine Edge/Mask.
Loads of info/help:
3. Re: Extract Filter?
Mathias Vejerslev Jan 29, 2013 9:14 AM (in response to SusanSherman)Look into the Quick Selection Tool. In combination with Refine Edge, it is much, much better than the Extract filter.
4. Re: Extract Filter?
Jeff Arola Jan 29, 2013 9:34 AM (in response to SusanSherman)If your on a windows system, you should be able to use the filters from the cs5 optional plugins in photoshop cs6.
http://www.adobe.com/support/downloads/detail.jsp?ftpID=4688
However, i would encourage you to try and learn doing extractions with the refine edge as mentioned above.
5. Re: Extract Filter?
SusanSherman Jan 29, 2013 10:10 AM (in response to Jeff Arola)I don't know if this filter was available with CS5 or not. I upgraded from CS4 to CS6.
6. Re: Extract Filter?
SusanSherman Jan 29, 2013 10:31 AM (in response to Curt Y)Curt,
Watched the video, he is using CS5. Step one is use quick mask tool. Step two is select Window/Masks...problem!
When I select Window, there is no Mask option in CS6.
How do I complete this?
Susan
7. Re: Extract Filter?
conroy Jan 29, 2013 10:48 AM (in response to SusanSherman)There is no Masks panel in CS6. Mask properties are now in Properties panel when a mask is targeted.
