1 2 Previous Next 46 Replies Latest reply on Feb 6, 2014 5:53 AM by Mike M
    General Error Message When Installing Flash Player on Mac
    Hmalina
      I have a new MacBook Pro.  I have OS 10.8.2.   I cannot get FlashPlayer to download.  I have tried uninstalling and reinstalling Adobe Flash Player 11 from the Adobe website.  Doesn't work.  Every time I try to download, I get an error message that says "Error: General Installation Error"   Can someone PLEASE help?  I've spent hours with this and am very frustrated.
        • 1. Re: General Error Message When Installing Flash Player on Mac
          chris.campbell Adobe Employee
          Thank you for posting and I apologize for the inconvenience this has caused.  Which browser are you using when this occurs?  Is the browser running, if so does the same error occur if it's closed?
          Could you please launch your Console application (Applications/Utilities/Console), verify that "All Messages" is selected in the left column, then in the upper right corner type "flash".  Please copy and paste the lines of text that appear in the main log area.
          Chris
          • 2. Re: General Error Message When Installing Flash Player on Mac
            Hmalina Level 1
            Thank you for your reply.   I am running Safari, and I have tried  it with
            the browser closed and open, and same result.  Here's the  string:
            1/29/13 9:14:23.111 AM coreservicesd[72]: Application App:"Install
            Adobe Flash Player" @ 0x0x7ffa02372980 tried to be
            brought forward, but isn't in fPermittedFrontASNs ( (
            ASN:0x0-0x4fc4fc:)  ), so denying.
            1/29/13 9:14:23.111 AM WindowServer[98]: Failed  setting
            the front application to Install Adobe Flash Player, psn  0x0-0x4fb4fb,
            securitySessionID=0x186f3, err=-13066
            1/29/13 9:16:36.000  AM kernel[0]: HFS: Vol: Flash Player Very Low Disk:
            freeblks: 0,  dangerlimit: 84
            1/29/13 9:17:17.590 AM sudo[6366]: Aaron : TTY=unknown ;  PWD=/ ;
            USER=Aaron ; COMMAND=/usr/bin/open
            http://get.adobe.com/flashplayer/completion/aih/?exitcode=255&type=install
            1/29/13  9:31:50.494 AM coreservicesd[72]: Application App:"Install
            Adobe Flash  Player" @ 0x0x7ffa0141e3c0 tried to be
            ASN:0x0-0x518518:) ), so  denying.
            1/29/13 9:31:50.494 AM WindowServer[98]: Failed  setting
            the front application to Install Adobe Flash Player, psn  0x0-0x517517,
            1/29/13 9:33:52.000  AM kernel[0]: HFS: Vol: Flash Player Very Low Disk:
            1/29/13 9:35:32.014 AM sudo[6521]: Aaron : TTY=unknown ;  PWD=/ ;
            1/29/13  9:44:32.000 AM kernel[0]: HFS: Vol: Flash Player Very Low Disk:
            freeblks: 0,  dangerlimit: 3
            1/29/13 9:46:55.473 AM coreservicesd[72]: Application  App:"Adobe Flash
            Player Install Manager" @ 0x0x7ffa01418520  tried to be
            ASN:0x0-0x545545:) ), so denying.
            1/29/13 9:46:55.474 AM  WindowServer[98]: Failed setting
            the front application to  Adobe Flash Player Install Manager, psn
            0x0-0x543543,  securitySessionID=0x186f3, err=-13066
            1/29/13 9:46:55.784 AM authexec[6588]:  executing /Library/Application
            Support/Adobe/Flash Player Install  Manager/fpsaud
            1/29/13 10:37:02.258 AM coreservicesd[72]: Application  App:"Install
            Adobe Flash Player" @ 0x0x7ffa02123b30 tried to  be
            ASN:0x0-0x57d57d:) ), so denying.
            1/29/13 10:37:02.258 AM  WindowServer[98]: Failed setting
            the front application to  Install Adobe Flash Player, psn 0x0-0x57c57c,
            1/29/13 10:39:02.000 AM kernel[0]: HFS: Vol: Flash Player Very Low
            Disk: freeblks: 0, dangerlimit: 84
            1/29/13 10:39:27.431 AM sudo[6839]:  Aaron : TTY=unknown ; PWD=/ ;
            1/29/13  2:54:59.429 PM coreservicesd[72]: Application App:"Adobe Flash
            ASN:0x0-0x597597:) ), so  denying.
            1/29/13 2:54:59.429 PM WindowServer[98]: Failed  setting
            0x0-0x594594, securitySessionID=0x186f3, err=-13066
            1/29/13 2:54:59.740  PM authexec[6892]: executing /Library/Application
            1/29/13 3:04:55.770 PM coreservicesd[72]: Application  App:"Install
            Adobe Flash Player" @ 0x0x7ffa014417d0 tried to  be
            ASN:0x0-0x5b65b6:) ), so denying.
            1/29/13 3:04:55.770 PM  WindowServer[98]: Failed setting
            the front application to  Install Adobe Flash Player, psn 0x0-0x5b45b4,
            1/29/13 3:06:56.000 PM kernel[0]: HFS: Vol: Flash Player Very Low  Disk:
            I look forward to your  response.
            Hilary
            In a message dated 1/29/2013 6:27:35 P.M. Central Standard Time,
            forums_noreply@adobe.com writes:
            created by Chris Campbell (http://forums.adobe.com/people/chris.campbell)
              in Installing Flash Player - View the full  discussion
            (http://forums.adobe.com/message/5032761#5032761)
            • 3. Re: General Error Message When Installing Flash Player on Mac
              We are actively investigating all Mac installation issues that have recently started appearing.  To help narrow down the problem(s), we ask that user's please generate a few installation logs for us.  The steps below should walk you through the steps.  If you are uncomfortable running these commands and would like to schedule a quick desktop sharing session, please contact me directly at ccampbel@adobe.com.
              1. Mount the Flash Player installer .dmg file
              2. Copy the "Install Adobe Flash Player" file to desktop or any other directory as preferred
              3. Open terminal and cd to desktop or the other directory
              4. Run the following command on terminal: ./Install\ Adobe\ Flash\ Player.app/Contents/MacOS/Install\ Adobe\ Flash\ Player –debug
              5. Once the install has finished, right click on the the Adobe Flash Player.app file and select "Show Package Contents"
              6. Navigate into the /Contents/MacOS folder
              7. Locate the host.developer.log and installer.developer.log and copy them to the desktop
              8. Navigate into ~/Library/Logs/ and locate the file FlashPlayerInstallManager.log.  Copy this to the desktop.
              9. Zip up all 3 files (host.developer.log, installer.developer.log and FlashPlayerInstallManager.log) and email them to ccampbel@adobe.com
              Chris
              • 4. Re: General Error Message When Installing Flash Player on Mac
                Hmalina Level 1
                That's a bit too sophisticated for me.  Let's do desktop sharing.  Let me know when.  I'll be on the computer the next couple hours and available.
                Hilary
                • 5. Re: General Error Message When Installing Flash Player on Mac
                  Hi Hilary,
                  I'm available now if that works.  Please shoot an email to ccampbel@adobe.com.
                  Chris
                  • 6. Re: General Error Message When Installing Flash Player on Mac
                    DGTechTeam
                    Hi Chris,
                    I also have a user with the same specs and issue. I'm not sure the terminal command succeeded successfully, but I'm sending you an email to follow up with a screenshot. Looking forward to your assistance.
                    Best,
                    Ian
                    • 7. Re: General Error Message When Installing Flash Player on Mac
                      Hi Ian,
                      Sent you email.  Please let me know how it goes.
                      Chris
                      • 8. Re: General Error Message When Installing Flash Player on Mac
                        astirusty
                        Run the following command on terminal  : “ ./Install Adobe Flash Player.app/Contents/MacOS/Install Flash Player –debug“
                        The default terminal shell willl not run the above command line.  The shell still sees the spaces between directory and file names.  I had to cd down to the where the install file was, rename the install file, and then run the program there.
                        To help people troubleshoot or debug failing installs, I would suggest Adobe substitute "_" (under bar) (or some other non-special character) for spaces in all directory paths and files it creates and uses.
                        From looking at the -debug output, I found that install program was failing because of:
                        a) it assumed there was already existing directory
                        b) existing file could not be written to
                        c) a problem with another program opening to many threads resulting in -10800 error
                        To further help people troubleshoot or debug failing installs, I would suggest:
                        a) failing output line written back to terminal's command-line be written to one of the log files.
                        b) add an option at the start of Install program to turn on debugging (-debug), and tell the user where the log files can be found
                        • 9. Re: General Error Message When Installing Flash Player on Mac
                          @astirusty - Thank you for pointing out the issue with the escaped spaces in the file name.  I've updated my instructions but you are correct that it would be easier if we had an easier way to generate debug information.  I'll pass this along to the installer team.  Would you mind sending me a copy of the logs that you created?
                          Chris
                          • 10. Re: General Error Message When Installing Flash Player on Mac
                            astirusty Level 1
                            Hello Chris:
                                >  Would you mind sending me a copy of the logs that you created?
                                 I deleted the logs after getting Flash Player to install.  I will check the Trash Can to see if the logs are still recoverable.
                            For me the logs were not helpful, whereas the error message generated from running the Installer from command-line of Terminal was.
                            Asti
                            Date: Fri, 1 Feb 2013 16:16:31 -0800
                            To: astirusty@hotmail.com
                            Subject: General Error Message When Installing Flash Player on Mac
                                created by Chris Campbell in Installing Flash Player - View the full discussion
                            @astirusty - Thank you for pointing out the issue with the escaped spaces in the file name.  I've updated my instructions but you are correct that it would be easier if we had an easier way to generate debug information.  I'll pass this along to the installer team.  Would you mind sending me a copy of the logs that you created? Thanks,Chris
                                 Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at http://forums.adobe.com/message/5041679#5041679
                                 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/5041679#5041679
                                 To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/5041679#5041679. In the Actions box on the right, click the Stop Email Notifications link.
                                 Start a new discussion in Installing Flash Player by email or at Adobe Community
                              For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
                            • 11. Re: General Error Message When Installing Flash Player on Mac
                              RanchinParadise
                              I AM NOT HAPPY AT ALL WITH ADOBE.  VERY POOR CUSTOMER SUPPORT.  I have a new Macbook Pro with latest Mountain Lion 10.8.2.  I get a general installation error when it has 55% downloaded.  Since I have only had this mac a week, I called apple support, they checked a few settings and had me try again while on the phone with them.  Same download error message.  They said call Adobe.
                              In talking with Adobe they wanted to remotely access my machine because they said mountain lion frequently had something they needed to change and for that there would be a fee anywhere from $99 - $149.  WHAT???
                              • 12. Re: General Error Message When Installing Flash Player on Mac
                                @RanchinParadise - No need to pay a fee, we can help you get Flash Player installed.  First I've got a few questions.  What browser are you using to download the Flash Player installer with?  Safari?  Would you be willing to generate and send me some debug logs so we can figure out what's going on here?  Please see this post for instructions:
                                http://forums.adobe.com/message/5034805#5034805
                                Chris
                                • 13. Re: General Error Message When Installing Flash Player on Mac
                                  RanchinParadise Level 1
                                  Thank you.  I am using Safari.  I will look in the link attached but I am 66 years old and not very computer literate.
                                  Sent from my iPad
                                  • 14. Re: General Error Message When Installing Flash Player on Mac
                                    No, starting in step 3 of your response on the attached thread, it gets over my head.  I dont know what terminal, cd means.
                                    Sent from my iPad
                                    • 15. Re: General Error Message When Installing Flash Player on Mac
                                      I understand.  If you are interested, please email ccampbel@adobe.com and we can setup a quick desktop sharing session and I'll get Flash installed for you.
                                      Chris
                                      • 16. Re: General Error Message When Installing Flash Player on Mac
                                        mrdredre
                                        The easiest workaround I found is selecting the "Notify me to install updates" option, instead of "Allow Adobe to install updates).  I suspect it has something to do with Mountain Lion requiring a higher level of authentication to install programs, or removing the ability for programs to autoupdate completely (complete speculation on the second part).  Just make sure to check for updates on a weekly, if not daily, basis.
                                        You may also need to go into System Preferences-->Security & Privacy-->Allow applications downloaded from: Anywhere. You'll have to put in an admin account password.
                                        • 17. Re: General Error Message When Installing Flash Player on Mac
                                          Kaolay001
                                          How i solved:
                                          4. Run the following command on terminal: sudo ./Install\ Adobe\ Flash\ Player.app/Contents/MacOS/Install\ Adobe\ Flash\ Player
                                          5. Insert the password when asked
                                          • 19. Re: General Error Message When Installing Flash Player on Mac
                                            Kaolay001 Level 1
                                            the error goes beyond my skill, but:
                                            1) delete the installation file you have on the desktop
                                            2) delete the dmg file
                                            3) re-download the package
                                            4) retry the 5 step below
                                            i suppose you have entered the password when asked right?
                                            • 20. Re: General Error Message When Installing Flash Player on Mac
                                              jfwmix
                                              I have been following the issues with installing the current Adobe Flash Player for Mac on the message boards since my Flash Player ceased functioning correctly this morning.
                                              http://forums.adobe.com/thread/1144035?tstart=0
                                              http://forums.adobe.com/thread/1149789?tstart=0
                                              • I was initially getting the Illegal Plugin message on sites with imbedded YouTube.  I downloaded the Flash Player Uninstaller and that remedied that problem but Flash is still not working
                                              • I've tried installing the Flash Player using the small 1MB download application located at: http://get.adobe.com/flashplayer/
                                              • I have also tried using Terminal as described in one of the Adobe forums
                                              • Both gave the same results (see attached screenshots)  I have tried this several times (each time uninstalling beforehand) and it always stops at the 7% and then gives the 47% on the timeout screen
                                              • It appears to be a downloading issue.  I was not able to find a direct link to the full 16MB Flash Player installer to verify it is a downloading issue.
                                              UPDATE:
                                              • I downloaded the "Download the Macintosh Flash Player 11.5 Plugin content debugger" from the following link and everything appears to be working correctly now.
                                              http://www.adobe.com/support/flashplayer/downloads.html
                                              Hope this helps everyone out.
                                              My rig:
                                              Mac OSX 10.7.5
                                              Safari Version 6.0.2 (7536.26.17)
                                              Mac Pro 2x 2.66 Dual Core Intel Xeon
                                              • 21. Re: General Error Message When Installing Flash Player on Mac
                                                Please see this post for details on how to generate installation logs (optional) and a link to our help documents that contains a link to the stand alone installer.
                                                I do not recommend users install the "debug" version of Flash.
                                                Flash Player installation issues with Mac OS X
                                                Chris
                                                • 22. Re: General Error Message When Installing Flash Player on Mac
                                                  JimK_aus
                                                  Hi Chris,
                                                  I just signed up to tell you that I'm also having exactly the same issue as OP. I get a general installation error at 55%.
                                                  Running on OSX 10.8.2. Safari 6. A lot of people on ML seem to have this problem. Please fix this asap.
                                                  • 23. Re: General Error Message When Installing Flash Player on Mac
                                                    HenryAZ
                                                    Here's another report of the same general error.   On system MacBookPro, running 10.7.5 and Safari 5.1.7, I download the Flash installer.  Adobe correctly identifies my system as OS X/Safari.
                                                    I get the general installation error at 51% every time, and every time the following error is thrown to my Console (system.log):
                                                    Feb/08/2013 2:35:15.091 PM [0x0-0x4f04f].com.solidstatenetworks.awkhost: LSGetApplicationForInfo() failed with error -10814 while trying to determine the application with bundle identifier org.mozilla.firefox.
                                                    It seems to me there is a disconnect there.  I do not even have Firefox installed on this system.  Nor is my Safari "user agent string" set to Firefox, which is borne out by Adobe's detecting my system as "Safari".  (My user agent string is set to Default).
                                                    So, why is the Flash installer even looking for a "bundle identifier org.mozilla.firefox" ??
                                                    • 24. Re: General Error Message When Installing Flash Player on Mac
                                                      alexbangs
                                                      Having this problem on a fresh install of 10.8.2.
                                                      Thanks to @mrdredre, the solution for me was to go to System Preferences, Security & Privacy, General tab, Allow applications downloaded from - make it "Anywhere".
                                                      After doing that, I re-ran the installer and it worked just fine.
                                                      Crazy that Adobe would release this new installer w/o having it signed so it works without changing this setting.
                                                      -- Alex
                                                      • 25. Re: General Error Message When Installing Flash Player on Mac
                                                        jfwmix Level 1
                                                        As the "debug" version is only for Flash content developers, it should mention that next to the link.
                                                        Why is is impossible to find the Mac Flash Plugin standalone application?  Can someone please post a link to this as the procedure on following page which the Adobe site directs the user to still does not work.
                                                        All I'm trying to do is fix something that was not broken until Friday morning.
                                                        Thanks.
                                                        JFW
                                                        • 26. Re: General Error Message When Installing Flash Player on Mac
                                                          jfwmix Level 1
                                                          Please disregard the above post.  I emailed Chris on Friday and got this email reply within a few hours which for some reason didn't show up in my inbox until this evening:
                                                          Hi John,
                                                          I think you’ll be happier with the non debug version of the player.  With the debug version you’ll start seeing errors that normally won’t be displayed when viewing webpages.  I’d recommend installing this version instead:
                                                          http://fpdownload.macromedia.com/get/flashplayer/current/licensing/mac/install_flash_playe r_11_osx.dmg
                                                          Chris
                                                          Thanks for the email, quick reply, and customer service as this seems to be working great.
                                                          Hopefully in the future, they will make this link readily available and easy to find online.
                                                          • 27. Re: General Error Message When Installing Flash Player on Mac
                                                            JoeInMV
                                                            Hi Chris,
                                                            I was able to get it to install from the terminal by using sudo.
                                                            $ cd Desktop
                                                            $ sudo ./Install\ Adobe\ Flash\ Player.app/Contents/MacOS/Install\ Adobe\ Flash\ Player
                                                            Without the sudo, I got the following error in the terminal:
                                                            2013-02-09 20:46:43.869 Adobe Flash Player Install Manager[49780:707] Unable to launch FPInstallHelper. Error = 'launch path not accessible'
                                                            • 28. Re: General Error Message When Installing Flash Player on Mac
                                                              hwe<at>uconn
                                                              I had this problem on an iMac running 10.7.5 and Safari 6.0.2.  I was able to solve it by running the download recommeded by jfwmix in reply # 26.
                                                              Hope this saves someone some time.
                                                              • 29. Re: General Error Message When Installing Flash Player on Mac
        @hweuconn - Did this occur today?  What type of error did you receive when you tried to initially install?
        • 30. Re: General Error Message When Installing Flash Player on Mac
        hwe<at>uconn Level 1
        Hi Chris,
        The user reported the problem Tuesday afternoon and I fixed it Wednesday morning, 3/13.
        Initially, I could download the small installer, but the main download would hang when 8% completed.
        We run ClamXav for anti-virus and Sentry is the active component, I disabled Sentry but the download still failed.
        • 31. Re: General Error Message When Installing Flash Player on Mac
        jeff_evans
        I have tried many of the suggestions from this thread but I'm still not able to get the latest Flash Player to install.  OS X 10.9 on a Mac Mini.  When I try the 11.9 installer that was linked by jfwmix above (post #26), it fails partway through.  When I examine the Console, it shows there was a crash log generated.  Pasted below are the contents of that crash log.  Any suggestions on what to try next?
        Nevermind, once I ran the uninstall procedures again, then restarted, then ran the installer linked by jfwmix in post #26, it worked this time.
        • 32. Re: General Error Message When Installing Flash Player on Mac
        awesomeben
        im using a Mac OS X and have a trouble with the name and password needed while installing adobe flash to my mac. I installed the adobe flash installer ,once i click it > install adobe flash player > open > i need to enter my name and password. Even after typing in my email and password i signed up from adobe. Its always wrong and even after i change my password multiple times its still wrong ):
        • 33. Re: General Error Message When Installing Flash Player on Mac
        Mike M Level 6
        The password required is your OS X administrator password. It has NOTHING to do with Adobe.com or any email account anywhere.
        You CANNOT install anything on a Mac unless you're a system administrator and provide the administrator password.
        • 34. Re: General Error Message When Installing Flash Player on Mac
        Ken Tannenbaum Level 1
        Chris....I'm one more stranded professional unable to work.  A senior Apple tech pointed me here.
        I'm running OS 10.8.5, Apple removed the previous flash player and we can't install v12.
        Stuck and in need of what you're already doing graciously.  The walk through install.
        Thanks, Ken
        • 35. Re: General Error Message When Installing Flash Player on Mac
        Mike M Level 6
        Ken,
        Are you also seeing this?
        Specifically, a "General Installation Error"?
        • 36. Re: General Error Message When Installing Flash Player on Mac
        Hey Mike, that's correct, I'm getting that too.  I haven't read this entire thread so maybe you know the following already.  An Apple tech tried every which way to work through the problem after telling me that Apple pulled the plug on a version of Flash which caused this mess.  He said there was a security reason for doing it and that Adobe was notified.  He also said Adobe created a FIX yesterday which was supposed to auto load to our computers.  That was all last night according to him.  THEN he gave up and pointed me to this thread.  He said if this doesn't prove okay, I'd need to reinstall my OS which is 10.8.5.
        Anyway, I noticed in this thread that Chris Campbell (with Adobe)is trying to help and at one point suggested downloading what I think is a previous version.  I'm about to try that.
        Good luck.
        • 37. Re: General Error Message When Installing Flash Player on Mac
        MIke, I just tried the fix Chris thought might work...Flash version 11.  No-go.  That wouldn't install either.
        • 38. Re: General Error Message When Installing Flash Player on Mac
        Mike M Level 6
        Good news:  You DON'T need to reinstall your OS, but.... If you upgrade to OS 10.9, it'll solve the problem. A lot of people are leery of Mavericks, but I've had it since the morning it was released, and I haven't had anything other than a minor annoyance with Finder looking for files to open in some (not all) apps.
        And I would not go back to that "Apple tech" because he has no clue what the real problem is. "and it ain't Flash Player"....
        Back in October, you installed the 10.8.5 update just like I did. And just like me, you suddenly saw the mach_kernel file in your Mac HD directory. But... unlike me, you weren't taught by the Mac guys at Intuit what it is, and you no doubt trashed it. THAT is the root of all your ills right about now. mach_kernel, is a base file for OS X. Without it, you can't install a lot of stuff and you can't update a lot of stuff.
        So... what to do?
        Like I memtiioned, upgrading will install a new one and you;re good to go, if you choose to go that route.
        If not, and you have a Time Machine, I posted instructions here: http://forums.adobe.com/thread/1318151
        If you DON'T have a time machine with a backup from before October 14, 2013, then you'll need "Plan B".
        Post back and let me know your situation, and I'll let you know what we can do to get you back in one piece.
        • 39. Re: General Error Message When Installing Flash Player on Mac
        Thanks, that's a fairly complex reply.   I do have Time Machine of course, and it goes back to before then so I'll read your post about it.  I'm a photographer and videographer so this stuff is critical to me.  Anyway, that's awhile ago but frankly, although I'm sure I did the 10.8.5 update, I doubt seriously that I trashed the "mach_kernel" since frankly, I'm not familiar with it so why would I?
        I have thought to switch up to Mavericks BUT, between my kid and my own experience with upgrades, I haven't wanted to fix what ain't broke.  Usually I jump on upgrades but there's some evidence I might have bigger headaches with Photoshop and Final Cut, which are my bread and butter.
        I'll check out your post about TM now.  Thanks very much.
        1 2 Previous Next
