1. Re: New! Put multiple fields on one line
radesjardins Jan 29, 2013 5:03 PM (in response to Randy Swineford)A very nice and functional upgrade. Thank you!
2. Re: New! Put multiple fields on one line
Jester4t2 Feb 28, 2013 10:24 PM (in response to Randy Swineford)Thank you Randy, I only downloaded the trail version, and it would seem that I cant add fields next to each other.
When i move the mouse over the top right hand corner, (next to the bin) it only allows me to change the field, I dont get the plus sign
3. Re: New! Put multiple fields on one line
Randy Swineford Mar 1, 2013 5:57 AM (in response to Jester4t2)If you are using the FormsCentral desktop app that is part of AXI then you will need to go to the Help menu and Check for Updates. You don't have the latest desktop client.
Randy
4. Re: New! Put multiple fields on one line
Jester4t2 Mar 1, 2013 6:12 AM (in response to Randy Swineford)YOU ROCK !!!!!
Thank you Randy - Up and running now
5. Re: New! Put multiple fields on one line
crystaldb Apr 9, 2013 7:15 AM (in response to Randy Swineford)Randy, thanks so much for this! I've been wracing my brain trying to figure out how to do this. Now I'm stuck trying to make the fields I'm adding line up correctly. for example:
Mulch ____ $_______________________
Dethatching ______ $_______________________
When I add the fields they are just going wherever they fall. Is there a way to adjust this?
THANK YOU!
6. Re: New! Put multiple fields on one line
Genevieve Laroche Apr 9, 2013 10:54 AM (in response to crystaldb) -
7. Re: New! Put multiple fields on one line
crystaldb Apr 9, 2013 10:55 AM (in response to Genevieve Laroche)It does. Thank you very much!
8. Re: New! Put multiple fields on one line
forms creator Sep 3, 2014 12:27 PM (in response to Randy Swineford)Hi. I am trying to place more than one field on the same line and it does not allow me to do so. I have Adobe Acrobat XI Pro ver 11.0.0 and am trying to use the FormsCentral that came bundled with it. Very disappointed that I can no longer create the intricate forms I once did in Adobe Pro.
