I cannot use joins in query of query, I try the old method using the ( + ) but no luck "Query Of Queries syntax error. Encountered ( + )."
Here is an example of my query code:
select p.part_id, s.supplier_name, s.second_name
from part p, supplier s
where p.supplier_id = s.supplier_id ( + )
and p.second_id = s.second_id ( + );
PART SUPPLIER_NAME SECOND_NAME
P1 Supplier#1 A
P2 Supplier#2
P3
P4
How can I do the same in query of query syntax?
Thanks!
I found a solution:
http://www.bealearts.co.uk/blog/2007/06/20/how-to-do-an-outer-join-in-query-of-queries/
I am not sure about my second condition. i create the join query for the empty columns.
select part.part_id, supplier.supplier_name, supplier.second_name
from part, supplier
where part.supplier_id = supplier.supplier_id
and supplier.second_id is null
union
from part, supplier
and part.second_id = supplier.second_id
union
select part.part_id, joinQuery.supplier_name, joinQuery.second_name
from part, joinQuery
where part.supplier_id not in (#ValueList(supplier.supplier_id)#)
Can anyone check and let me know if this is correct?
My final result have one less row from parts table.
Right general idea but the details are wrong. I do it like this:
select q1.f1, q2.f2
from q1, q2
where q1.f1 = q2.f1
union
select q1.f1, 'some constant' f2
from q1
where f1 not in (<cfqueryparam value = "#valuelist(q2.f1)# list="yes")
Thanks for you reply and help Dan,
What about my second condition "SECOND_NAME"?
The "part" table have supplier_id and second_id. The "supplier" table have few supplier_id's but some second_id's are nulls.
My first part match the records from "part" table and supplier with the same supplier_id but not second_id.
The second part of my query match both the supplier_id and second_id.
The third part will get the "parts" that doen't match with supplier using supplier_id or second_id.
I hope this is clear.
Best,
Maybe we should back up a bit.
How did you get into the situation where you have to do a Q of Q?
