21 Replies Latest reply on Jan 31, 2013 8:25 AM by jpcsolutions
    Using getDate in input field, and displaying daysLeftUntil in another field...
    jpcsolutions
      I am trying to use JS in an adobe form I created. I have a date field in which the user enters the current date. Then, in another field, the days left until the end of the year are displayed. I can do this great in HTML, but behavior in Acrobat isn't quite the same.
      Here's what I have so far, but applying it proves difficult.
      function DayDiff(StartDate)
          var TYear=StartDate.getFullYear();
              var TDay=new Date("January, 01, 2014");
              TDay.getFullYear(TYear);
              var DayCount=(TDay-StartDate)/(1000*60*60*24);
              DayCount=Math.round(DayCount);
          return(DayCount);
        • 1. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
          First of all, what's the point of this line:
          ? It doesn't change anything...
          Furthermore, you should use the getTime() method on your Date objects to get the difference between them in ms, after which you can divide it to get the results in days (that you already do).
          • 2. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
            jpcsolutions Level 1
            You're right. It didn't anything, so I changed it. However, I'm still unable to have a user enter the date in one input box and have it output the number of days between that input date and the end of the year... How do I make that display happen. It's just not working for me. I have the display field set as "hidden but printable"...does that make any difference?
            • 3. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
              You're close, but not quite there... What are passing to this function, exactly? Where are you converting the string the user inputs to a Date object?
              If you want to set year of TDAY to the year following that the user entered, use this: TDay.setFullYear(TYear+1);
              • 4. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                I guess that's where I'm having trouble. In HTML, the variable for the input text box is the converted string... but in Adobe, I'm not sure how to pass something to this function.
                I'm lost! Can you provide more detailed feedback?
                • 5. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                  In Acrobat (also in HTML pages, I believe) you need to explicitly convert a
                  string into a Date object in order to be able to work with it as such.
                  There are two ways of doing it: The Date constructor (like you used to
                  create the other Date object) and an Acrobat-specific method called
                  util.scand(). The latter is somewhat better than the constructor because
                  you can specify a date pattern, for example:
                  util.scand("mm-dd-yyyy", "20-12-2013")
                  will return a Date object for Dec. 20th, 2013.
                  • 6. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                    Okay... so I research the util.scand() and re-wrote the whole thing using that function.
                    var strStart = this.getField("StartDate").value;
                        if(strStart.length) {
                             var dateStart = util.scand("mm/dd/yyyy",strStart);
                    //Calculation Pemformed
                     var oneDay = 24 * 60 * 60 * 1000;
                                 var dueMillis = dateStart.getTime() + 5 * oneDay;
                                 var dueDate = new Date(dueMillis);
                    //Date is printed
                      event.value = util.printd("dd",dueDate);
                    This is like 99% of what I need to do.
                    However, I see how to figure out a future date, but how do I write the difference between the start date (StartDate) and the end of the year?
                    Also, I need to be able to print "Days Left" after the # of days is displayed.
                    This...
                    ("" + dd + " days left",dueDate);
                    doesn't work in Acrobat...
                    Any ideas?
                    • 7. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                      You were on the right path before to calcluate the number of days to the end of the year...
                      This will give you the first day of the next year from dateStart:
                      var firstDayNextYear = util.scand("dd/mm/yyyy", "01/01/" + dateStart.getFullYear()+1);
                      Now you want to calculate the difference between them, right?
                      var diffMs = firstDayNextYear.getTime() - dateStart.getTime();
                      var diffDays = diffMs / oneDay;
                      And to apply it to the field where this is the calculation script you simply use:
                      event.value = diffDays + " days left";
                      • 8. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                        Here's the entire thing, the way we've worked it out so far... But it's not rendering the amount of days between the StartDate and the end of the year... Not sure where I went wrong... Ideas?
                        //Start 'Days Until' Script
                        var firstDayNextYear = util.scand("mm/dd/yyyy", "01/01/" +
                        oneDay;
                        //Date is printed
                        Thanks!
                        • 9. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                          Are there any error messages in the console? Does it produce any output at all?
                          • 10. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                            No... the output box doesn't produce anything. And it did before... I'm not sure where to go from here...
                            • 11. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                              Start debugging... Add console.println() commands to check the values of the various variables and make sure that they are what you expect them to be...
                              Also, you might want to use valueAsString in your first line instead of value.
                              • 12. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                I started debugging and this is where I'm at right now...
                                 getField("DATE") is null
                                1:Field:Calculate
                                TypeError: getField("DATE") is null
                                1:Field:Calculate
                                firstDayNextYear is null
                                13:Field:Calculate
                                TypeError: firstDayNextYear is null
                                13:Field:Calculate
                                1:AcroForm:PTO:Calculate
                                13:Field:Calculate
                                13:Field:Calculate
                                I'm not sure I really understand this too well...
                                • 13. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                  There's not field in your file called "DATE"... Remember that JS is
                                  case-sensitive, so if your field is actually called "date", you have to
                                  write it that way.
                                  • 14. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                    Okay... I made an adjustment and now I'm getting some output at least... Here's the code...
                                    var firstDayNextYear = util.scand("mm/dd/yyyy", dateStart.setFullYear()+1);
                                    oneDay;
                                    //Date is printed
                                    Now, it's displaying NaN days left in the output field.
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    13:Field:Calculate
                                    In the form PTO, I had the following:
                                    DATE(YEAR(StartDate),12,31)-StartDate
                                    I have lower-cased the "date" word and completely removed this line. The error still doesn't go away when I re-debug it. Any ideas?
                                    And what do you think this line means?
                                    13:Field:Calculate
                                    I think we're getting somewhere, but not sure how to fix some of these things.
                                    • 15. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                      You messed up the definition of firstDayNextYear. Go back to my code and
                                      see how it should be done.
                                      • 16. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                        Here is my code up to this point. You'll notice that down below, I have re-compiled the code and
                                        the debugger is showing significantly less errors.
                                        var firstDayNextYear = util.scand("mm/dd/yyyy", "01/01/" + dateStart.getFullYear()+1);
                                        oneDay;
                                        //Date is printed
                                        These "null" errors... I am not sure where to go with those.
                                        And there's a "date is not defined" error, too.
                                        12:Field:Calculate
                                        12:Field:Calculate
                                        date is not defined
                                        1:Field:Calculate
                                        ReferenceError: date is not defined
                                        1:Field:Calculate
                                        Any ideas here?
                                        • 17. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                          I re-wrote the code for you, and added some debugging commands:
                                          event.value = "";
                                          var strStart = this.getField("StartDate").valueAsString;
                                              console.println("strStart:"+strStart);
                                              console.println("dateStart:"+dateStart);
                                              var firstDayNextYear = util.scand("mm/dd/yyyy", "01/01/" + (dateStart.getFullYear()+1));
                                              console.println("firstDayNextYear:"+firstDayNextYear);
                                              console.println("diffDays:"+diffDays);
                                          • 18. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                            Okay try67... We're really close now...
                                            Here's the debugging info. The decimal place goes out about 14 places, but it's behaving properly.
                                            12:Field:Calculate
                                            12:Field:Calculate
                                            date is not defined
                                            1:Field:Calculate
                                            1:Field:CalculatestrStart:03/01/2013
                                            dateStart:Fri Mar 01 2013 00:00:00 GMT-0700 (US Mountain Standard Time)
                                            firstDayNextYear:Wed Jan 01 2014 00:00:00 GMT-0700 (US Mountain Standard Time)
                                            diffDays:306.00000001157406
                                            date is not defined
                                            1:AcroForm:PTO:CalculatestrStart:04/05/2013
                                            dateStart:Fri Apr 05 2013 00:00:00 GMT-0700 (US Mountain Standard Time)
                                            diffDays:271.00000003472223
                                            date is not defined
                                            I'm going to see what I can do now about the decimal places...
                                            • 19. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                              Okay... So, I played around with the User Input part of the form a bit and put in different dates. If I put in a date where the days remaining in the year is a whole number, then it shows like 335 Days Left (I used 01/31/2013). But, when I put in tomorrow's date (02/01/2013), I get 334.00000001157406.
                                              I think it might be something in the milliseconds calculation. What are your thoughts?
                                              • 20. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                                Yes, probably... Change this:
                                                To:
                                                var diffDays = Math.floor(diffMs / oneDay);
                                                • 21. Re: Using getDate in input field, and displaying daysLeftUntil in another field...
                                                  That worked. This is great!
                                                  Thanks for all your help with this. You've certainly taught me quite a bit about js in Acrobat. You're really good at this!
