1. Re: Viewing Camtasia SWF output in Robohelp 10
Captiv8r Jan 30, 2013 10:49 AM (in response to R Tomchuk)Hi there
Can you tell us what version of Camtasia you are using? And what your output options were? And what the output is you are creating in RoboHelp?
Cheers... Rick
2. Re: Viewing Camtasia SWF output in Robohelp 10
R Tomchuk Jan 30, 2013 11:07 AM (in response to Captiv8r)I'm using Camtasia Studio 8.
These videos are being sent to me by another trainer to embed in Robohelp, which is the challenge I'm facing. If I had my way, I'd have developed them using Captivate instead. I tested a Captivate SWF and it was viewable in Robohelp. Instead, he created these in Camtasia and wants me to make them available in a help system. I did try publishing the raw CamProj myself, using custom production settings: MP4 - Flash/HTML5, video size: 1250x720, everything else left on the defaults. The results in Robohelp have been the same, as detailed above, either way.
Thanks for responding quickly!
3. Re: Viewing Camtasia SWF output in Robohelp 10
Captiv8r Jan 30, 2013 11:15 AM (in response to R Tomchuk)Thanks for providing part of what I asked for. Now about the rest!
From RoboHelp, what is the output you are attempting to create? I'd like to know that so I can test as closely as I can to what you are trying to do.
Cheers... Rick
4. Re: Viewing Camtasia SWF output in Robohelp 10
Captiv8r Jan 30, 2013 11:16 AM (in response to Captiv8r)Oh, and one other thing. In RoboHelp, are you attempting to insert the Camtasia stuff within another RoboHelp topic or do you plan on playing it on a page all by itself?
5. Re: Viewing Camtasia SWF output in Robohelp 10
R Tomchuk Jan 30, 2013 11:26 AM (in response to Captiv8r)I'm attempting to insert the video within a topic, either by using the Insert Multimedia/Demo menu option, or dragging it over from the Project Manager pod.
Would it work better create the video as its own page?
6. Re: Viewing Camtasia SWF output in Robohelp 10
R Tomchuk Jan 30, 2013 11:28 AM (in response to R Tomchuk)As for your first question, I'm trying to generate a Web Help HTML layout (not HTML5).
7. Re: Viewing Camtasia SWF output in Robohelp 10
Captiv8r Jan 30, 2013 11:50 AM (in response to R Tomchuk)Okay, I've sorted making it work. Here are the notes.
First, it's worth noting that while a SWF is in the mix of Camtasia created files, it's not the main file. It's just a supporting file among many others. The main file appears to be a file with .mp4 as the file extension. (I said that because with video content, the extension is really more of a container or wrapper than anything else. So other than knowing it's got an extension of .mp4, you really don't know for certain what's inside.)
So with Camtasia output, it's not as simple as just clicking Insert > Multimedia/Demo.
What I did to make it all work was to inspect the HTML page Camtasia created and copy the iframe code from the Camtasia page to the topic page where I was inserting the video. Then I had to create some folders in my RoboHelp project that matched the folders Camtasia created. After that, I added the files from the Camtasia folders to the new RoboHelp folders as baggage files. Once I did that things seemed to work just fine.
Alternatively, you may omit the steps of copying the iframe code from the Camtasia file and simply import the Camtasia HTML file and link to it so it opens as any other topic would and completely fill the topic pane.
Hope this helps... Rick
8. Re: Viewing Camtasia SWF output in Robohelp 10
R Tomchuk Jan 30, 2013 3:49 PM (in response to Captiv8r)I ended up going with the alternate option and just linking the videos directly in the TOC. That did work for me, and it's better for my users anyway. One less click for them!
Thanks so much for all your help, Rick!
9. Re: Viewing Camtasia SWF output in Robohelp 10
Buzzme4Solution Sep 25, 2014 6:04 AM (in response to Captiv8r)Hi Captiv8r
I tried inserting a mp4 and .swf file to a topic and generating a chm output but I am unable to view the video. I have installed the RH11 trial version.
Does chm support video files or the video file can only be viewed in web Help or Responsive HTML5 layout. I got the same black screen error and I installed the Flash Player, K Lite Codec & quick time player just to rule out and check but nothing worked. I need your help and guidance on how I can insert videos in chm files.
Sridhar
10. Re: Viewing Camtasia SWF output in Robohelp 10
Captiv8r Sep 25, 2014 10:42 AM (in response to Buzzme4Solution)Hello again
Yeah, I'm not sure why, but playing video inside a CHM seems to be more trouble than it should be. I played a bit this morning using Camtasia 8 and I seem to have found a process that works from that version. I used the "Custom Production Settings" from Camtasia 8. Then elected to use the MOV Quicktime Movie option. This caused me to have to make a few modifications in the RoboHelp topic after I browsed to and selected the resultant MOV file. I had to edit the HTML code to manually configure the playback size. I also had to configure autostart to true as well as autoplay. And, to fully view the playback controls I had to actually adjust the overall height of the movie to be taller than what I had configured it to be in the Camtasia output settings.
I would strongly encourage you and anyone else that reads this thread to submit a WishForm to ask Adobe to make the process of inserting video simpler. You do that using the link below:
Cheers... Rick
11. Re: Viewing Camtasia SWF output in Robohelp 10
Buzzme4Solution Sep 26, 2014 1:55 AM (in response to Captiv8r)The MOV option does not work for me so I have decided to go with Resposive HTML5 output for now.
I have submitted the feedback through WishForm and thanks for the information.
Cheers,
Sridhar
