10 Replies Latest reply on Feb 5, 2013 1:33 PM by Radsvid789
    Problems with selection.fill/pathItem.fillPath -- Ps CS6, JSX, Windows
    Radsvid789
      Hi all,
      First post here
      I've started lately to play around with extended javascript (jsx) scripting on Photoshop CS6 (using 32-bit version on Windows 7 Ultimate).
      I've had much trouble with 'fill' commands.
      This one here gives me an
      Error 1200: Internal error
      Line: 5
      ->  app.activeDocument.selection.fill( myColor );
      var myColor = new SolidColor();
      app.documents.add( 100, 100, 72, "tmp", NewDocumentMode.RGB, DocumentFill.TRANSPARENT );
      app.activeDocument.selection.selectAll();
      I read somewhere that giving all the parameters to the fill method could solve it, but it gave me the same result.
      I've also tried the fillPath method from PathItem, but it gave also an internal error (1200).
      var docRef = app.documents.add(500, 700, 72, "Simple Line")
      var lineArray = new Array()
      lineArray[0] = new PathPointInfo
      lineArray[0].kind = PointKind.CORNERPOINT
      lineArray[0].anchor = Array(100, 100)
      lineArray[0].leftDirection = lineArray[0].anchor
      lineArray[0].rightDirection = lineArray[0].anchor
      lineArray[1] = new PathPointInfo
      lineArray[1].kind = PointKind.CORNERPOINT
      lineArray[1].anchor = Array(150, 200)
      lineArray[1].leftDirection = lineArray[1].anchor
      lineArray[1].rightDirection = lineArray[1].anchor
      lineArray[2] = new PathPointInfo
      lineArray[2].kind = PointKind.CORNERPOINT
      lineArray[2].anchor = Array(100, 200)
      lineArray[2].leftDirection = lineArray[2].anchor
      lineArray[2].rightDirection = lineArray[2].anchor
      var lineSubPathArray = new Array()
      lineSubPathArray[0] = new SubPathInfo()
      lineSubPathArray[0].operation = ShapeOperation.SHAPEXOR
      lineSubPathArray[0].closed = true
      lineSubPathArray[0].entireSubPath = lineArray
      var myPathItem = docRef.pathItems.add("A Line", lineSubPathArray)
      myPathItem.fillPath(myColor, ColorBlendMode.NORMAL, 100, true, 0.0, true, true)
      This example only works if there is not parameters at all given to fillPath (it's filling with black).
      Does anyone know how I could work around this? Is it a known bug?
      Thanks all!
