6 Replies Latest reply on Jan 31, 2013 12:52 PM by George_Johnson
    Variable Drop Down Issue.
    fousthvk Level 1
      I am trying to set 3 drop down lists with the same values from a master list. I can get it to set one field but if I add an additional line to the code and call out the additional fields I get a syntax error.
      Here is the code.
      var plCode = {
                             PL1: [ ["-"], ["Double 7"], ["Triple 5"], ["Half-Round"],["Hand-SplitShake"]],
                             PL2: [ ["-"], ["Double 6"], ["Single 7"], ["Double 4"],["Double 4.5 DL"]],
      function SetProductLine()
         if(event.willCommit)
            var boName = event.target.name.split(".").shift();
            var lst = plCode[event.value];
            if( (lst != null) && (lst.length > 0) )
               this.getField(boName + ".Row1_ProfileName").setItems(lst);
               this.getField(boName + ".Row2_ProfileName").setItems(lst);
               this.getField(boName + ".Row3_ProfileName").setItems(lst);
            else
               this.getField(boName + ".Row1_ProfileName").clearItems();
               this.getField(boName + ".Row2_ProfileName").clearItems();
               this.getField(boName + ".Row3_ProfileName").clearItems();
      After the else works but after the IF statement I cannot have more then one line. If I close it in {} it allows me to use it but only seems to repect line one after the IF statement.
        • 1. Re: Variable Drop Down Issue.
          George_Johnson MVP & Adobe Community Professional
          Does this work:
          function SetProductLine() {
              if (event.willCommit) {
                  if (lst) [
                  } else [
          • 2. Re: Variable Drop Down Issue.
            fousthvk Level 1
            not sure but this did.
            var plCode = {
                                   PL1: [ ["-"], ["PL1 Double 7"], ["PL1 Triple 5"], ["Half-Round"],["Hand-Split Shake"]],
               if(event.willCommit){
                  if( (lst != null) && (lst.length > 0) ){
                     this.getField(boName + ".Row1|ProfileName").setItems(lst);
                     this.getField(boName + ".Row2|ProfileName").setItems(lst);
                     this.getField(boName + ".Row3|ProfileName").setItems(lst);
                  else
                     this.getField(boName + ".Row1|ProfileName").clearItems();
                     this.getField(boName + ".Row2|ProfileName").clearItems();
                     this.getField(boName + ".Row3|ProfileName").clearItems();
            I really apreciate you replying. am not just trying to clear some fields if specific things are selected. But I think I can handle that. THANKS!
            • 3. Re: Variable Drop Down Issue.
              fousthvk Level 1
              George how do a set a varible to a list of a dropdown menus current list?
              • 5. Re: Variable Drop Down Issue.
                fousthvk Level 1
                Will that allow me to then use that variable to use in conjunction with setitems to set another drop down with another drops downs values?
                • 6. Re: Variable Drop Down Issue.
                  That depends on how you code it, but yes, that's certainly possible.
