1. Re: Url redirect problem - Can anyone advise?
Konsum Tech - Madonna Jan 31, 2013 6:47 PM (in response to Conceptstore)Hello Conceptstore,
You can still use htaccess in BC, you just have to upload this in the root folder. We have been using .htaccess for this kind of needs.
The other thing you can do is create an A-Record in BC and point this to your blog's IP address this way anyone who access blog.concptstore.co.uk would pull out the contents from there. So it's creating a sub-domain in BC that points to external server. All blog pages you have in BC use 301 redirect for each, this can be found in more options once you already in web page environment.
Hope this helps!
2. Re: Url redirect problem - Can anyone advise?
Conceptstore Feb 1, 2013 4:47 AM (in response to Konsum Tech - Madonna)Thanks Madonna, that was just the answer we were looking for. Your help is appreciated, greatly
3. Re: Url redirect problem - Can anyone advise?
Conceptstore Feb 4, 2013 2:08 AM (in response to Conceptstore)Hello Madonna,
We've incorporated teh htaccess file but noticed that it didn't work. Whats more other BC posts claim that htaccess doesn't work on the BC system. Is that true?
4. Re: Url redirect problem - Can anyone advise?
Liam Dilley Feb 4, 2013 2:17 AM (in response to Konsum Tech - Madonna)This is untrue.
Sorry Concept, you were given bad advise
Htaccess is something that works on apache servers. BC does not run on Apache, it is .NET and this does not run this file.
5. Re: Url redirect problem - Can anyone advise?
Conceptstore Feb 4, 2013 2:49 AM (in response to Liam Dilley)Thats what I thought??? - Woudl you have any suggestion as to how we can fix this problem? As it stands we're loosing all of our old links becuase BC can't handle a permenent "directory" redirect.
6. Re: Url redirect problem - Can anyone advise?
Conceptstore Feb 4, 2013 4:50 AM (in response to Conceptstore)----Edit ---- The below does nota ctually work, it misses part of the url out
We've managed to come up with a very tedious solution.
In order to solve the problem above we have to manually input each url in the "URL Redirects" section of BC, one at a time.
It can't be done via the excel template upload option becuase for some reason BC won't allow it due to our old site structure, howver it does work manually.
If anyone has any better ideas, we'd appreciate it as we'll be typing out over 100m urls.
