2 Replies Latest reply on Jan 31, 2013 8:50 AM by Jaime Desytec
    View > Show > Selection Edges option appears disabled
    Jaime Desytec
      Hello...
      I use PS CS6 for Windows. When I select a layer by mean of Ctrl-Click on layers palette, selection edges is not shown. When I go to menu View > Show > Selection Edges i realize that option is disabled.
      How can I proceed?
      Thanks in advanced
      Jaime
        • 1. Re: View > Show > Selection Edges option appears disabled
          What exactly are you selecting? This will not work with layers that have full document size...
          Mylenium
          • 2. Re: View > Show > Selection Edges option appears disabled
            Jaime Desytec Level 1
            Hello and thanks for answering.
            I remember the all days, when I used PS C3. I added a layer, make some graphics on it and if for some reason I needed to select th whole layer, I just did it by Ctrl-click on it and see how the selection edges appear in the layer. That way, I can modify the selection, for example, if I needed to smooth it or make some other operation.
            By following the same procedure it did not work in CS6.
            For instance, I needed to draw a smoothed border around the layer.
            Finally I solved it by placing 4 guides in each edge of the layer, and then making use of the selection tool, but that is not the idea. The ideal would be to select the layer as I did in CS3.
            Best regards,
            Jaime
