3 Replies Latest reply on Feb 6, 2013 10:26 PM by radzmar
    Percentage Issues
    csb102155 Level 1
      Hi,  I continue to have problems with percentages.  How can I format a number field so that it writes a percent like 5.5 as 5.5%.   I've tried different methods and it goes all over the place.  Any assistance would be greatly appreciated.
      Connie
        • 1. Re: Percentage Issues
          radzmar Adobe Community Professional & MVP
          simply use the display pattern num{zz9.9 '%'}
          • 2. Re: Percentage Issues
            csb102155 Level 1
            I tried what you suggested in your message above, but it still comes out wrong.  5 x 1.0% should equal to 0.050 and it comes out as 5.  Can anyone help?
            Connie
            • 3. Re: Percentage Issues
              did you write the % within the quotes?
              If not the pattern works differently. The percentage pattern only returns integers.
              But when you use quotes, then the % character is just a string attached to the formatted value.
              Examples:
              Pattern                         Entered Value            Displayed Value
              num{z,zzz,zz9%}         1                                   100%
              num{z,zzz,zz9%}         5.5                                550%
              num{z,zzz,zz9%}         0.5                                50%
              num{z,zzz,zz9%}         0.25                              25%
              num{z,zzz,zz9.88'%'}  1                                   1%
              num{z,zzz,zz9.88'%'}  5.5                                5,5%
              num{z,zzz,zz9.88'%'}  87                                 87%
