1 Reply Latest reply: Jan 31, 2013 4:07 PM by Rick Gerard RSS
    A virus that affects...  After Effects CS6?
    lou4uandme Community Member
      Hi everyone,
      Although I read online that others had the same issue as me, I couldn't find any solution.
      please see  post # 15   http://forums.adobe.com/thread/630006   POST # 15
      After I restarted my pc,
      After effects cs6 is staying that "I have more than 1 copy of plugins and to remove one of them".
      Now, I know this is a normal message from adobe, however, I know it's not true because:
      1. I have NO extra copies of plugins.
      2. AE is saying I have a copy of EVERY SINGLE plugin installed. (around 300 )
      3. I removed ALL plugins until AE could ***** about duplicates.
      Once I removed all of them, I got  " TRACKER _REGISITER:MISSING SUITE "
      "AE can not  continue"
      Has anyone experienced this before?
      Lou
        • 1. Re: A virus that affects...  After Effects CS6?
          Rick Gerard CommunityMVP
          I'd run the AE cleaner tool, remove the Library/Application Support/Adobe/Common/After Effects CS6 directory completely, then re-install and re-install your plug-in's.
          You shouldn't go about removing plug-ins from their folders and expect things to work. All it takes is deleting one and you can get the error message you are seeing.
          It's very unlikely that a virus caused your problem. It could have been a host of other things. It only takes one duplicate hiding somewhere in an alias or installed in the wrong directory to foul things up. If you've got 300 additional plug-ins then it's not surprising that something got broke during an update or an install especially if your plug-ins were not installed with an installer.
