8 Replies Latest reply on Feb 1, 2013 7:07 AM by gkaiseril
    Round Number
    Gdaimon Level 1
      as a value rounded to nearest 1000 example: 2500 = 3000, 2400 = 2000
      event.value = Math.round (this.getField ("cas93"). value * (this.getField ("porAran"). value / 100
        • 1. Re: Round Number
          This function will do it for you:
          function roundToNearestThousand(x) {
              var d = x % 1000;
              if (d<500) return (x - d);
              else return (x + (1000-d));
          You can use it like this:
          roundToNearestThousand(2400) // will return 2000
          roundToNearestThousand(2500) // will return 3000
          roundToNearestThousand(2900) // will return 3000
          • 2. Re: Round Number
            Gdaimon Level 1
            not work, casilla1 = 5%, casilla2 = 250000 = 1250 = value is 13,000, then:
            function roundToNearestThousand (this.getField ("casilla2"). value * (this.getField ("casilla1"). value / 100) {
                 var d = x% 1000;
                 if (d <500) return (x - d);
            can you tell me if what I'm doing wrong?
            • 3. Re: Round Number
              Don't divide the percentage field by 100. Its value is by definition
              between 0 and 1, so what you see as 5% is actually 0.05.
              • 4. Re: Round Number
                Also, you're not using the function correctly
                You need to leave the function as it is, and use it like this:
                var v = +this.getField ("casilla2").value * +this.getField ("casilla1").value;
                event.value = roundToNearestThousand(v);
                • 5. Re: Round Number
                  Gdaimon Level 1
                  excuse me I do not understand, look at the following code and income get error in line 2
                  var v = +this.getField ("cassilla2").value * +this.getField ("casilla1").value;
                  event.value = roundToNearestThousand(v){
                  var d = v % 1000;
                      if (d<500) return (v - d);
                      else return (v + (1000-d));
                  • 6. Re: Round Number
                    George_Johnson MVP & Adobe Community Professional
                    It would have to be something like this if you want to do it that way:
                    // Custom Calculate script for text field
                    function roundToNearestThousand(v) {
                        var d = v % 1000;
                        if (d < 500) return (v - d);
                        else return (v + 1000 - d);
                    The function should really be defined in a document-level JavaScript and the custom calculation script for the field would be what try67 posting in response #4 above.
                    • 7. Re: Round Number
                      Gdaimon Level 1
                      great works and thank you very much, it is possible to tell me where I can learn more of the Acrobat JavaScript APIs.
                      Thousand and thousand thanks for the attention and collaboration
                      • 8. Re: Round Number
                        A more general solution can be found at Grade School Sample Files by D.P. Story. In the sample instruction file is a rounding function that eliminates the rounding error found with JS's Math.round method and can round either to the left or right of the decimal point.
