0 Replies Latest reply on Feb 1, 2013 8:10 AM by SG
    Modify translation workflow
      I need to modify translation workflow to have all language checkboxes "checked" by default. I noticed that the sidekick widget code has the below code for the language selections
                          "xtype": "selection",
                          "cls": "x-form-field",
                          "name": "langTargets",
                          "fieldLabel": CQ.I18n.getMessage("Select Languages"),
                          "type": "checkbox",
                          "options": langOptions
      Did not see the "checked" config available for the 'selection' xtype. I have a workaround to add a new "Select All" check box.
                          "xtype": "checkbox",
                          "name": "allLangTargets",
                          "fieldLabel": CQ.I18n.getMessage("Select All")
      and in handler to check if the "Select All" is checked or not. But I prefer to find how to get all language checkboxes checked by default.
      The second question I have is how do I implement this change for my application. Do I just create the same file (modified version) under the apps folder ?
      Thanks in advance for help!
