2 Replies Latest reply on Feb 1, 2013 12:26 PM by met547
    Can't merge data files into spreadsheet on secured document
    met547
      I created a form in Acrobat X Pro. The form was secured first using a password to restrict editing, just allowing fillin form fields. Then enabled file saving by Enable Addtional Features, and save the file. Everything works Ok: can't edit the form and allows me to save it, but when I use Merge Data Files into Spreadsheet to export the data, the exported CSV file is empty. Can't export data. So I tried to remove the password protection but got the following message:
      You cannot change security on this document because the document is signed or certified.
      Is there anything I can do to fix this? Either been able to export data or removing protection.
      Thank you.
