4 Replies Latest reply on Feb 1, 2013 4:21 PM by dhmarsh1020
    Download Typeface into CS6 Indesign
    dhmarsh1020
      How do I load a newly downloaded typeface in CS6?
      [moved to InDesign forum from product download/Install forum]
        • 1. Re: Download Typeface into CS6 Indesign
          Steve Werner Adobe Community Professional & MVP
          Fonts aren't downloaded to InDesign. They are installed in your operating system (Macintosh or Windows). They are then available to all your applications, including InDesign CS6.
          • 2. Re: Download Typeface into CS6 Indesign
            dhmarsh1020 Level 1
            how are they installed into the operating system?   OS X version 10.8.2
            • 3. Re: Download Typeface into CS6 Indesign
              You can either install fonts manually, or with the Font Book utility (Applications > Font Book), or with a third-party font manager.
              For beginners on the Mac, the Font Book utility is a good choice.
              Usually, you'll install them in your Home folder. Here is a description from the Help Center (Finder > Help > Help Center):
              Choose Font Book > Preferences, and select an option from the Default Install Location pop-up menu:
              User: The fonts are available only to you. They’re copied to a folder in your home folder (~/Library/Fonts/).
              Computer: The fonts are available to any user on this Mac. They’re copied to a folder on the startup disk (/Library/Fonts/). You must enter an administrator’s password to install fonts here.
              A user-defined library: The fonts are available only to you. A reference to them is stored in the library. If a font is on an external or network disk, it’s available only when the disk is attached.
              Since it sounds like you're a beginner, you might think of picking up a good book on using the Macintosh. A good choice are David Pogue's Missing Manual books. Since you're using Mountain Lion (Mac OS 10.8.x), you'd want "OS X Mountain Lion, The Missing Manual."
