2 Replies Latest reply on Feb 4, 2013 12:50 AM by MrTIFF
    Size of placed PDF Page
    pkrk Level 1
      After placing a page from a PDF, I want to display the size of the page in a text frame.
      The closest to the size of the PDF page that I get is when using
      app.pdfPlacePreferences.pdfCrop = PDFCrop.cropMedia;
      Sometimes I get and expected size like 8.5 by 11 but some PDFs give me a size of 8.4###### x 10.9######.
      If I open up the PDF in acrobat that in indesign showed 8.4###### x 10.9######, it shows 8.5 x 11.
      Is my only way around this is to set up some rounding/precision routine?
      Thank you in advance!
      ** I calculate the size but it starts with geomtric bounds having a lot more decimal places than expected.
        • 1. Re: Size of placed PDF Page
          Vamitul Level 4
          use javascript's math rounding methods (floor, ceil, round). i don't know if ExtendeScript supports the .toFixed method, but that would be great.
          if not, here is a prototype for it (don't know where i got it, it's in my library for some time now, and i don't think i ever used it):
              Number.prototype.toFixed = function(precision) {
                  var power = Math.pow(10, precision || 0);
                  return String(Math.round(this * power)/power);
          • 2. Re: Size of placed PDF Page
            MrTIFF Level 3
            Yes, ExtendScript does support toFixed(), but you need a toFixed() that also trims any trailing zeros:
            * same as toFixed(), but trims off those annoying trailing zeros
            * @param decimalPlaces maximum number of digits to the right of the decimal point
            * @returns the same string as toFixed(), except that any trailing zeros are removed
            Number.prototype.toFixedNice = function(/**Number*/decimalPlaces) /**String*/
                 return Number(this.toFixed(decimalPlaces)).toString();
            So if you include the above in your extendscript, you can do this:
            var x = .999999999999;
            alert(x.toFixedNice(5)); // gives "1", instead of "1.00000"
