This problem is intermittent. I have tried all the remedies for Flash Player on the help page. No help, problem persists. Everything seems to be going fine and Flash Player locks up, becomes non responsive and the "General Error" page pops up.
Is this specific to the Flash Player 11.7 beta, or are you seeing it in other versions. (You can check the installed version by right-clicking on some Flash content and looking at the bottom of the context menu that opens.)
This has been happening through several versions. Happened in 9 and 10.
Just making sure, we're talking about Flash Player 9 and 10, right?
Yes, we are talking about Flash Player 9 and 10.
Moved to Using Flash Player, as this isn't specific to the Beta.
If possible, please post a screenshot of this page so we can try to see what's going on.
I will take a screen shot and post it the next time the problem occurs. I really appreciate your taking an interest in this problem. I have taken all the steps indicated on the MSN games site regarding "General Errors".
I have not experienced this problem since updating to version 11.6.602.180.
The most helpful thing for me in terms of figuring out what's going on is to look at some crash logs (for crashes in current versions).
To enable crash logging, add the following line to C:\Windows\System32\Macromed\Flash\mms.cfg using a text editor (notepad):
CrashLogEnable=1
After the crash, you should be able to find a crash report at:
WindowsXP: C:\Documents and Settings\[username]\Local Settings\Temp"
Vista and Higher: "C:\Users\[username]\AppData\Local\Temp\"
The filename will be player_crash_log_<number>.mdmp They're pretty big, and there may be more than one. Just check the date and time to make sure you're grabbing the right one(s).
Send Chris or I a private message and we'll give you a location to upload it. If you can collect a couple, that would be very helpful.
Jeromie
I have tried to implement the CrashLogEnable=1, but I cannot be sure it is really in the cfg file because I cannot break the security on the Macormed\Flash folder. I am an experienced windows user and know how to manipulate the file and folder properties. But even running notepad with administror privleges does not allow saving the cfg file with the crashlog value set when the file is reopened with notepad. I am still having the problem were my game crashes intermittenlty. No crash dumps have been generated when failures have occurred in the last few days. Thanks for your help.
It sounds like the file is in use, although it's typically only read when Flash Player first starts up. You might just reboot to make sure that anything keeping it locked exits and releases it.
When this happens, You might want to save to a known good location (like the desktop), then use the file explorer to overwrite the \macromed\flash\mms.cfg file. Explorer is smart enough to prompt for admin elevation rights and allow the copy to occur.
