2 Replies Latest reply on Aug 30, 2006 6:53 PM by new2oop
    creating an array of movieclips in AS2 oop
    new2oop Level 1
      Long time proceedural programmer trying to switch to OOP. Using the book "Object Oriented Actionscript for Flash 8" I've created the example of a class with a movieclip passed to it as a parameter. Trying to expand that to an array of clips/classes and without success.
      Here's the class:
      class Location extends MovieClip {
      var targetMC:MovieClip;
      var x:Number;
      var y:Number;
      function Location(targetMC:MovieClip, x:Number, y:Number) {
      this.targetMC = targetMC;
      this.x = x;
      this.y = y;
      moveTo(x,y);
      function moveTo(x:Number,y:Number) {
      this.targetMC._x = x;
      this.targetMC._y = y;
      and for a single clip the following works well in the fla
      attachMovie("dot","dot",1,1,100);
      var myLocation:Location = new Location(dot, 200,300);
      However when I try to create an array of 'dots' it doesn't work.
      var myLocation:Array = new Array();
      for(x=0;x<5;x++) {
      attachMovie("dot","dot"+x,1,1,100+x);
      var myLocation[x]:Location = new Location(_root["dot"+x], 200,100+x*30);
      Also how do I avoid using the _root command in this?
